Group Buy; JQ Werks & Madtrace Clubsport Magnetic Paddle Shifters for 992
Old 05-05-2023, 09:34 AM
  #151
dixonk
dixonk's Avatar
Received 1,732 Likes on 777 Posts
Originally Posted by al_b
In one of the steering wheel removal threads, there was a strong caution to avoid removing the clock spring with the wheel but can’t recall the steps needed. is it just that the second wiring harness needs to be removed after the airbag removal?
Got the paddles yesterday like most, and they do seem high-quality. Didn’t realize that it came with a second set of paddles they were hiding under the foam block.
Looking forward to hearing about everyone’s install and use experiences, I think I may wait for the GT3RS style paddles as I don’t want to take the wheel off twice.
Thanks @mattchow for organizing this.
Looking at the assembly picture it looks like you may be able to swap the paddles with an Allen key while the wheel is on. I could be wrong. Anyone with the paddles installed know the answer to that?
Old 05-05-2023, 10:05 AM
  #152
911Castle
911Castle's Avatar
Swapping paddles with wheel on seems to be confirmed. Next, remember not to long ago, you could FED ex overnight a letter to your neighbors house and it would still go to the Memphis TN hub and back. The shipping oddities are not really that odd.
dixonk (05-05-2023)
Old 05-05-2023, 11:23 AM
  #153
shrimp money
shrimp money's Avatar
Received 5,190 Likes on 2,067 Posts
This is on a 991 wheel, but you can definitely change it after the wheel is reinstalled.
dixonk (05-05-2023)
Old 05-05-2023, 11:29 AM
  #154
dixonk
dixonk's Avatar
Great because it looks like something you may adjust a few times to find that perfect placement as well.
Old 05-05-2023, 05:06 PM
  #155
audiophilitis
audiophilitis's Avatar
Install completed -- pretty straightforward process, but now have a pesky CEL that won't go away despite two reset attempts (disconnect/reconnect negative terminal). Anyone have a similar issue?
Transformed shifters though and are now more tactile with a pronounced clicking sound.
Old 05-05-2023, 05:08 PM
  #156
Rennolazine
Rennolazine's Avatar
992?
Old 05-05-2023, 05:28 PM
  #157
22992
22992's Avatar
trick with the top connector? Mine is very difficult to remove and is not coming off with minimal force??
Old 05-05-2023, 05:32 PM
  #158
Shogunade
Shogunade's Avatar
Received 2,007 Likes on 1,129 Posts
pull the green connector straight out. It may come all the way out, but that's alright. It'll cIip back in. Then to get the yellow connector out push down from the top like you're trying to lower it. If that doesn't work you gotta pull out from both sides. DO NOT take the steering wheel off without undoing them or your clock spring will eject the ribbons.
mattchow (05-05-2023)
Old 05-05-2023, 05:37 PM
  #159
22992
22992's Avatar
owe u a beer. Would have never thought it needs to come out. I’m back on track now!
Old 05-05-2023, 06:04 PM
  #160
audiophilitis
yes
Old 05-05-2023, 06:30 PM
  #161
mattchow
mattchow's Avatar
Originally Posted by dixonk
Mine shipped from Altus, OK which is 2 hours away to California and then back to Oklahoma again. WTF? Out for delivery today after taking a tour of the western United States I guess. Talk about taking the scenic route
fairly certain they all shipped from CA then out to everyone. I can create a label that originates from anywhere I want, but will update to the actual hub the package is received at.
Old 05-05-2023, 11:20 PM
  #162
22992
22992's Avatar
Couple of tips for install:
I found it easier to use an allen wrench to remove the airbag
My window auto up/down and adjustment when enter/exit was not functioning after disconnecting the battery. Roll window all the way up and then hold the up button for a few sec. To reset. Check before slamming the door, or the window will bounce around in there and make some noises you don’t want to hear
Old 05-05-2023, 11:40 PM
  #163
Shogunade
Shogunade's Avatar
Glad to hear everything worked out. How is it? Magnetic magic?
Old 05-06-2023, 01:41 AM
  #164
Pak992
Pak992's Avatar
Just installed mine as well they are great. The tips here helped so the install only took 20 minutes and that included cleaning the dash etc since it was easier with the wheel off.
Old 05-06-2023, 02:43 AM
  #165
reddsektor
reddsektor's Avatar
Got mine today, still mustering some courage to install after reading about spring ribbons error lights and hard clips lol but probably just me being overly paranoid for what shouldn’t be too hard of an install
Quick Reply: Group Buy; JQ Werks & Madtrace Clubsport Magnetic Paddle Shifters for 992
