CTEK battery maintainer
#76
Those leds are as worthless as **** on a boar.
adm63 (05-15-2023)
#77
Called CTEK and rep tried his best to convince me comfort connector was functioning properly (battery is dead, wait for charge, etc) I finally convinced him I was pretty sure cable was kaput (cc flashes green lights which turn to red after a few hours, charger error light on, connected for 24 hrs and status light is stuck on step 1). Should have replacement cable “by end of week”. Kinda surprised with CTEK's reputation that it appears there is a QC issue with the CC cables. Really hope replacement will solve the problem and be reliable.
#79
Your install was so simple, I did the same thing. To insure good contact, I used a little dialectic grease on the bolt threads. The standard eyelet connector is too short to get past the cowl riser, but the optional one is (barely). I can now access with the frunk closed, which is a major point. If the battery dies, I can plug in with car locked and frunk closed and use the CTEK recovery mode. Hopefully, I'll never have to do that.
vg247 (05-29-2023)
#81
#83
Noco genius 5 hooked up with no issues
The following 3 users liked this post by westcoastj:
#84
Received 2,842 Likes
I connected a CTEK to my car for the 1st time this week and even with a new battery, fitted that day by Porsche, the amber LED came on and the charger sat in '3' for a couple of hours before finally going to '4' and eventually all the way to '8'. Then when I took the car out on Saturday and drove it for 50 miles or so, and connected the charger up afterwards, it did the same again. i.e. amber LED on the connector then '3' on the charger for a while before eventually going to '8'.
Do others here find the same pattern? Just trying to understand if what I'm seeing is considered normal and is what I should expect. Call me wary after so many battery issues....!
#85
Your experience duplicates mine which I believe is normal. I don't think indicator lights are very accurate or meaningful. As long as charger progresses through cycle with no abort/error lights, I’d say you are good.
#86
#87
#88
#89
I know this has been discussed thoroughly but still have not found a consensus on whether to order the 56-629 with M6 eyelets or the 56-382 with M8 eyelets.
I think I prefer attaching to the strut tower brace since there is nothing else attached at that point. If I opt for the 56-629 will the larger bolt on the strut tower pass through the M6 eyelet? Or will I have to go with the M8?
Also does anyone know the correct torque specs for this strut tower bolt when retightening? It seems like a large bolt and would like to retorque to factory specs.
If there is an advantage to attaching to the smaller bolt behind the strut tower, I would like to hear them?
DoubleD992GTS (06-28-2023)
#90
