CTEK battery maintainer
#121
On my 718 the passenger outlet works great, the 992 not so much. I have tried many different methods so looks like it's time to go directly to the battery.
355Shawn (01-12-2024)
#122
AGM Battery
CTEK Charger https://www.amazon.com/CTEK-40-206-5...hoCSwAQAvD_BwE
Lots of pictures on how to connect to the battery in here (mine are the best ), or you can get the cigarette lighter plug from Ctek and go that route (not really recommended IMHO).
What is interesting is it looks like something is already connected to your battery?
Not sure about what is connected, it’s bone stock - so nothing that wasn’t added at the factory.
I’ll have to compare my pictures to others.
Thank you.
#123
The following 5 users liked this post by tourenwagen:
23 gts (01-12-2024),
355Shawn (01-12-2024),
dg108 (01-12-2024),
FirstF80InSpace (01-26-2024),
Icegrill (01-12-2024)
#124
My 2024 GTS w/ RAS and PDCC came w/ an AGM (build date 04/2024, Canada). Installed the M6 eyelet adapter + the female cigaretter adapter on the charge-o-mat pro from the dealer from the 1st day I brought her home. Cut the +ve eyelet end and slid it into the +ve battery terminal and -ve/ground eyelet in the battery brace M10 nut (perpendicular) to the battery. Works just fine!
