Cargraphic Valve Control Unit
Old 06-10-2023, 09:41 PM
  #511
Tobeit
Tobeit's Avatar
Received 1,521 Likes on 744 Posts
Here we go - IPE and Cargraphic Controller
https://youtube.com/shorts/T2MCydRs7OU
The following 2 users liked this post by Tobeit:
tourenwagen (06-12-2023), ZacapaXO (06-10-2023)
Old 06-11-2023, 05:21 PM
  #512
SA_992SMT
SA_992SMT's Avatar
Installed the valve controller yesterday and everything worked as expected. To echo everyone else, the sound difference is very noticeable and sounds awesome. I purposely toggled the valves off before shutting down the car. With today's startup, the valves were open and the following message came on with the first drive session. Also, the Cargraphic remotes weren't working (the valves wouldn't close when pressing the #2 button). After shutting down and restarting the car after about two hours, everything worked as it should and the "reduced engine power" message was gone.
By the way, I have a MT and didn't notice any negative effect throttle response. Some others felt they did.
Old 06-11-2023, 05:48 PM
  #513
Vicbastige
Vicbastige's Avatar
Are you satisfied that all four connections were snug? Just a guess.
Old 06-11-2023, 06:08 PM
  #514
blackairforce1
blackairforce1's Avatar
I'm still waiting on an interior sound comparison of 1-3K RPM pull before purchasing
Old 06-11-2023, 06:33 PM
  #515
Tobeit
Tobeit's Avatar
Any video taking with a phone inside a cabin will not really sound like the real thing. I tried but thought not to post as its just not the same as in real. In my case, the interior sound is what makes me not want to use it too often. Like someone said before, even at idle the entire cabin has some slight vibration and when pushing it its not just loud but the cabin drones (remember I used it with IPE valved exhaust, not PSE, which is already markedly louder and more aggressive). Okay for the occasional fun kick but not for my daily use. From outside, it sounds great.
blackairforce1 (06-12-2023)
Old 06-11-2023, 06:36 PM
  #516
shrimp money
shrimp money's Avatar
Received 5,367 Likes on 2,135 Posts
From a GTS or an S?
Old 06-11-2023, 06:41 PM
  #517
AdamIsAdam
AdamIsAdam's Avatar
Received 4,075 Likes on 1,769 Posts
I see no downside to the Cargraphic aside from spending the money. You can switch it off and put the EV back to stock with the push of a button. How many mods can but reverted back to stock with the touch of a button?
The following 2 users liked this post by AdamIsAdam:
SamD (06-11-2023), Vicbastige (06-11-2023)
Old 06-11-2023, 06:45 PM
  #518
Tobeit
Tobeit's Avatar
True
Old 06-11-2023, 07:02 PM
  #519
SA_992SMT
SA_992SMT's Avatar
Pretty confident. I will likely confirm again to make sure. I think someone else got the "reduced engine power" message" and theorized that the car's ecu and/or the cargraphic controller ecu had to learn how to talk to each other. We'll see happens tomorrow.
Old 06-11-2023, 08:16 PM
  #520
SPIKES
SPIKES's Avatar
Originally Posted by Scottykenneth
Anyone get their GT3 HomeLink to work? I get the remote to register on the PCM HomeLink but when I go to press it on the PCM nothing works. I set up both Valves Open & Valves Closed options.
same here....only works sometimes
Old 06-11-2023, 08:48 PM
  #521
AdamIsAdam
AdamIsAdam's Avatar
On mine, it only works when I'm not in my crowded neighborhood, too much electrical interference there. Also remember that the car is designed to transmit that signal forward to the garage door, as you approach, not backwards to the engine bay, which is shielded behind a firewall. On my Cayman, the transmitter is in the passenger side headlight.
Old 06-11-2023, 11:32 PM
  #522
Tobeit
Tobeit's Avatar
Mine works fine via PCM. Initially had it accidently programmed with geolocation and menu disappeared as soon as I left home. Quick redo/fix and now works as intended.
Old 06-12-2023, 12:09 AM
  #523
Arroqueno
Arroqueno's Avatar
What is the benefit of programming HomeLink over using the remote? Is it the fact that you can activate it via the programmable button?
Old 06-12-2023, 12:29 AM
  #524
Tobeit
Tobeit's Avatar
Convenience.
Old 06-12-2023, 08:36 AM
  #525
GoCards67
GoCards67's Avatar
So for those of us that think the Homelink is clunky for the purpose of activating the Cargraphic valve controller...Where is everyone putting the remote? I am looking for a good place to mount it that is easy to get to, and is mostly invisible. I know someone mounted to the steering column adjustment. Looking for other options here.
Quick Reply: Cargraphic Valve Control Unit
