Cargraphic Valve Control Unit
#586
#587
#588
Received 4,075 Likes
Here is how to program the Cargraphic for startup in either OEM or in Open mode:
The start mode can be freely programmed as required. Last state: Press the button for "Sport mode" 5 times within 5 seconds.
Other modes: Press the button for the mode you want to program as the start mode for about ten seconds.
The valves open and close 5 times to confirm the successful programming of the start mode.
#589
Finally drove with the top up today and I kept fiddling with the key fob because it was so quiet.
I drove for like 80 miles thinking it was broken.
Then I tried turning it back off and heard how quiet “off” really was. I was so used to the sound with the top down….
I feel bad for those of you with roofs.
I feel bad for me when I have a roof…🤣
Master Deep (07-14-2023)
#590
jhenson29 (07-14-2023)
#591
Master Deep (07-16-2023)
#597
#598
I installed mine and at the next start up received the "reduced power, ok to drive get to a workshop" message. Has anyone else gotten this message and if so how did you fix it?
Also I can't shut the valves using the fob or the homelink. Any help is appreciated.
#599
It seems like the unit is broken if nothing is working
#600
First, I had my first similiar CEL. I had been messing with the fob before shut down and the car started with valves fully open which seemed to cause the fault. I shut it down, restarted it and no problems.
As for the valves not actuating, if you have sport exhaust it can seem like it isnt working from inside the car. I'd be sure to do a visual inspection with PSE off (if you have it) and vales open on the fob. Looking in the tips you can see if they are open or closed for certain. If they are not working it sounds like an issue with the module.
