Self melting windshield moulding?
#46
There are a lot of posts and threads on this.
It isn't a "caulk". It's a polyurethane sealant/adhesive.
There's no rubber seal. If there is a plastic trim strip, it's a gap filler for cosmetic purposes.
Getting a windshield replaced for the reasons noted in the photographs in this thread seems unnecessary to me. This seems like a problem that can be fixed with a rag and some alcohol.
Getting the windshield replaced unnecessarily seems to me like an invitation to further problems. If the install isn't done very carefully, the car can end up with scratches in the paint around the windshield (leading to rust, especially in the corners), and poor bonding (leading to leaks).
All modern cars have their windshields glued in with polyurethane.
Having had windshields replaced on other cars, and having had problems like leaks and cracked glass, I would avoid a replacement if possible.
#47
Happy Thanksgiving.
Quick bit of clarification seems to be needed on this thread:
-- The windshield is a piece of glass that is bonded in with urethane windshield black adhesive. Pretty standard. This urethane adhesive is not failing on 992's and the urethane adhesive is what creates airtight/watertight seal and holds the window glass in.
-- However, the 992 windshield glass comes WITH a rubber/plastic molding permanently attached to it that is mostly I'd imagine for cosmetic/debris reasons. Lots of cars actually have similar. This is not a waterproof seal, in fact if it were, it would trap water between it and the urethane adhesive bead that holds the glass on.
-- This rubber/plastic debris trim is not replaceable as a separate spare part. This part is affixed to the windshield glass upon manufacture of the glass, and it is what is deteriorating.
-- So the correct repair is new glass(with new trim integral to the glass)
FYI other manufacturers have had this exact same issue over the years (e92 M3, some Land Rovers, and I'm pretty sure mid 2013-2016 or so Boxsters/Caymans had the exact same issue). I would not be surprised if Porsche comes up with a replacement seal part that can be popped in / on after the deteriorating seal is somehow manually removed, as a full windshield replacement for the issue is costly and can create other problems.
I would agree 110% with those of you who are saying that windshield replacement invites other problems. It's so true. I had a much loved e30 M3 that got a new windshield, and the tech stopped the work and refused to put the new window in -- multiple rust spots where whoever had at some point replaced the windshield had gouged metal through the paint and primer. Had it fixed at a body shop then put a new window in. Bummer, and completely invisible to me until I'd had the windshield removed. This is what I'd worry about 5-10-15 years down the line w/ these 992 windshields.
The following 3 users liked this post by Nashvegas:
#48
Happy Thanksgiving.
#49
I am not aware of any of the internal workings at Porsche (as much as I wish I was!) -- but I dare say they should better micromanage their glass suppliers because, you are right, this has been happening for 8-10 years on various Porsches... it's so dumb.
HouTexCarreraS (11-24-2022)
#51
Received 2,907 Likes
Happy Thanksgiving.
eagle1960 (11-26-2022)
#52
Latest update,
After waiting for 2 months and no responses from either Porsche or the dealership, I decided to pay and get this fixed. $2775 Canadian dollar is the cost for Porsche windshield and labour. The car is in storage and also for sale.
All the best to you folks and a great holiday season.
#53
Latest update,
This makes zero sense to me.
If I were going to sell the car, I would just grab a rag and some acetone and clean the smear off the pillar, rather than wasting $2,775 I'm not going to get back.
The problem is purely aesthetic. It's not causing any water or air leaks.
#55
both of the right and left radiators are totally exposed at speeds and those plastics little g-strips they use to cover the radiators are NOT sufficient and don't close under conditions they should be. if you daily drive your 992 on todays roads and run your AC your radiators will get hit with objects other then bugs and it is a part of the car. if something hits it hard enough to break the radiator vent it can leak and cause cooling issues, which does make it is Porsche issue. it is indeed a design issue they should cover. granted, like everything Porsche the parts are not extremely expensive compared to other European car parts but labor is. regardless, Porsche should be way more open to hearing cases on this. Porsche should be more aware of this and i hope they will take a closer look at this matter in the future.
my 992 has just under 6K miles on it and both of my radiators look like they have been hit several times with rocks, etc. it is not as bad as others i have seen but still this is something Porsche really needs to take a closer look at.
the GTS has even less coverage then the C/CS which makes it easier to damage, which makes no sense to me (aside from getting more airflow into them, which again is a Porsche design).
paint chips, etc if you wash your car regularly you can stay on top of or have your detailer take care of and a few paint chips won't change the value of your car. a left radiator with a bird imprint can! not that it is all about value but really ... those radiators on the 992 are so exposed from the factory and if that is the case Porsche should either make them bullet proof or cover with a grill cover or cover under warranty in the event something happens to them.
good morning!
#57
When I took delivery of my 2020 992 (manufactured in 2019), I encountered a similar issue. The dealer had to source a new windshield from the factory since resealing wasn't possible then. Although the dealer claimed this was an unprecedented problem, it's questionable whether the same claim made by a Porsche service department would be credible three years later.
I later discovered from an upholstery shop owner, who frequently repairs European car interiors, that European Union regulation of Volatile Organic Compounds (VOCs) caused a reformulation in adhesive and sealant products. This resulted in less effective formulations. The issue might be traced back to the 2019 update of Directive 2010/75/EU of the European Parliament.
Mikster (08-22-2023)
#58
i just took my 2020 C4SCab in for 30K service. I showed the windshield to my service advisor. The seal is incorporated into the windshield itself. He submitted pics to the Porsche warranty department and was able to replace the entire windshield/seal under warranty. Looks great now.
#59
Just noticed it on my 22’ Turbo S, I was wiping my windshield and saw the black glue melting on top my windshield trim. Pissed off and decided to search, sure enough it’s common thing.
my 991.2 4S and 991.2 TS didn’t have this.
gonna ask the dealer, windshield got some chips anyway, would be nice to have a clean windshield again.
vg247 (08-04-2023)
#60
