Self melting windshield moulding?
#31
The windshield should be replaced under warranty, no argument about that. I just wanted to share I had a vastly different experience from the OP.
#32
Had my 2021 C2 windshield replaced this week due to the same issue. I printed out 34 pages of Rennlist complaints on this issue and dealer happily replaced the windshield under warranty. Hope you have the same positive experience I had. If your dealer gives you any trouble I would suggest reaching out to Porsche North America.
#33
I see where you are located, not sure which dealership you are referring to, but you openly criticized Porsche Centre Vancouver regarding their pricing for trade in value on this forum and said you bought your car from Kelowna, 4 hours away. I have had amazing experience with Porsche Centre Vancouver going above and beyond to get stuff covered under warranty that is questionable. I probably wouldn’t publicly criticize a dealership on the forum unless I was likely done with my relationship. My suspicion is that your approach might have something to do with the results.
Regarding to this windshield matter, I’ve not named any particular dealership in the region. There are great people out there trying to make the right thing happen and I appreciate their efforts. However, not hearing anything from Porsche after 6 weeks surely does not help maintaining any sorts of relationships in this case.
I chose to update this ongoing situation because I started this thread and there are also others in this community dealing with same or similar issues; therefore, I believe some of them must be curious about the progress.
#34
#35
BTW - I believe you don't need to worry about leaks as a result of this issue. The windshield is actually sealed to the car with urethane or whatever adhesive is used to glue in windshields. This rubber trim is merely a cosmetic / debris trim.
(Pacific NW here also, lots of rain)
#37
Call PCNA, I did that when the dealership did not acknowledge, it is a well known issue and actually documented that a replacement is needed. In my case i was told that
#38
I just don't understand these dealers that are refusing to replace the windshield under warranty. Why would they care--it's just more warranty service business for them and going to bat for the customer is always a good business practice. My dealer had no problem with this at all and promptly did the work.
Drew46 (11-22-2022)
#39
There are a lot of posts and threads on this.
It isn't a "caulk". It's a polyurethane sealant/adhesive.
There's no rubber seal. If there is a plastic trim strip, it's a gap filler for cosmetic purposes.
Getting a windshield replaced for the reasons noted in the photographs in this thread seems unnecessary to me. This seems like a problem that can be fixed with a rag and some alcohol.
Getting the windshield replaced unnecessarily seems to me like an invitation to further problems. If the install isn't done very carefully, the car can end up with scratches in the paint around the windshield (leading to rust, especially in the corners), and poor bonding (leading to leaks).
All modern cars have their windshields glued in with polyurethane.
Having had windshields replaced on other cars, and having had problems like leaks and cracked glass, I would avoid a replacement if possible.
#40
#41
Getting my windshield replaced today. I called the service advisor and told him what was happening, took a few pictures and he said let me order and once it gets in we can schedule service.
He said he was aware of this and it's covered under warranty.
'21 S
'21 S
aggie57 (11-23-2022)
#42
#43
Don't you think if it would be that easy that Porsche service would be asked to do that and not replace the entire windshield? Also, many on this forum have their windshields replaced w/o any issue you describe...and its done 1000's of times on all kinds of cars every day. I think doing what you suggest invites more ugliness than having the dealer replace it properly.
Rust caused by scratches around the windshield won't show up for several years, but quicker in cars exposed to salt.
#44
Received 2,907 Likes
All the more reason to have Porsche replace it while under warranty.
#45
As another data point, I pointed out the melting trim to my dealer while the car was in yesterday and they ordered a new windshield - said it was a known issue.
