Preparation for Porsche Dashcam (Front and Rear)
#106
The rear cam wire is the same connector as the front cam one. I haven't checked where the pre-wired connector is. It should be a simple plug-in as well.
#107
Nice write up. Appreciate it. One question, is there a way to flip it so you can mount it on the passenger side of the rear view? I saw a video of an install just like yours on a RH drive in the UK and it was mounted on the left as well. That makes sense on a RH, and it would make sense to me that it should be mounted on the opposite side for us LH cars.
When I tried to put it on passenger side, I checked the image view, the driver side view is not wide enough where it may miss something from the driver side if someone approaches the car very closely.
So I put the Lens in center.
#108
Now pre-wiring option connects them, when installing OEM dash cam, it's a plug-in work, no need wiring work anymore.
#110
I just compared the camera wiring diagram to the harness
The prewired female connector connections in the overhead console are
Red/White is 12v hot all the time
Brown is Ground
Black is switched 12v
The camera harness connections are
Red 12v all the time
Black is Ground
Green is switched 12v
These connections don't matter if you are simply connecting a Porsche camera to the prewired plug.
If you plan on making your own harness you need to confirm these "pinouts".
Utilizing this connector eliminates the need for a mirror tap and will provide a dedicated fuse for your camera and / or radar detector.
Brown is Ground
Black is Ground
The following 4 users liked this post by audi4t:
#111
The OEM product contains two cams in one retail box (For pre-wiring option). Without pre-wiring option, the retail box only has one front cam.
Event though the pre-wried version has rear cam inside, I didn't see price difference.
#112
Brown is Ground
Black is Ground
Brown is Ground
Black is Ground
I assume the pre-wiring has put the dedicated fuse on?
I did check the fuse box on the driver side, it's so hard for me to understand these fuse slots.
#113
If your VIN has pre-wiring option, they will send both frond and rear cam in one box.
#114
It has the Pre-Wiring option. I send them my VIN and it should show the option. It is strange that with pre-wire option, they will include 2 cameras but w/o that option, only one camera. Maybe just tell them that you have the pre-wire option ordered (no vin yet, advanced order) so that they will provide 2 cameras.
With pre-wiring option, it has only two male connector wires.
Without pre-wiring, the kit may include the additional wiring pieces (and fuses) which allow you to bridging the power to fuse box.
#115
#116
Order this part number from any Porsche dealer it’s OEM I have a cabriolet and there is much less space in the overhead lighting console since the latch for the top uses much of the space I cut off the connect from the harness and made my own harness to feed my radar detector and an aftermarket dash cam
The following 3 users liked this post by audi4t:
#117
audi4t (02-27-2023)
