Preparation for Porsche Dashcam (Front and Rear)
#256
Thanks for sharing the detailed instructions and that Ebay listing @audi4t - was able to hardwire my Uniden R7 to switched power using the front dashcam prep outlet! I want to note that the wire colors on your Ebay harness pinout weren't accurate for me (each individual unit probably has different arbitrary wire colors), but of course the positions were correct; I'd guide others to rely on positions and not wire colors. Pardon the blurry pictures:
#257
#258
2nd Gear
Just installed the front for my 2024 Turbo S (got it from dealer Friday). The Yellow (orange to me) connector is to the left under the headliner. Very hard to see. For me it was easier to remove the R visor clip to allow the headliner to flex more. My son in law held the headliner part while I pushed the dashcam connector in. They could have made this a lot easier and put a hot plug in the forward cover!
The connector is in the dark area up there!
Peeking out!
Peeking out!
#260
@txpackers: I did exactly what @malba2366 describes, using this mirror tap kit and a couple of Wago lever nuts. Unfortunately didn't take pictures of the modified harness before installing. I left the other pigtails alone, though you could cut them off to save space.
I have the pre-wiring and still haven’t decided how I want to use it. The real world reviews of the Porsche dash cam aren’t the best which is disappointing. I’m considering the Escort MAXcam 360c for an all in one solution or the Uniden R7 with a Blackvue. I added the dash cam wiring on my build since it was cheap and would make it easier to connect things like this.
I still hold out hope that the Porsche branded dash cam gets better.
#261
This is very helpful. Thank you both for sharing.
#262
What I've most recently read is that there is a new firmware update for the dashcam itself that greatly improves connectivity and usability. One user reported it was "close to perfect now". I'm still a month from collecting my car, but fully intend to install the Porsche-branded cam.
#264
Dashcam install in a YR23 992 911 GTS
Someone help me understand...Why are the dealers (North Carolina/Raleigh/Durham) asking $800 -1200 plus to install/mount the dash cam when the car is already prewired.? note: i provide the camera from SUNCOAST Porsche. what is so special or difficult/time consuming about this install??
#265
#266
It’s so frustrating… why don’t they just install at factory? Maybe I should call Porsche NA, but then again, to what end?
#267
#268
I installed the Porsche camera kit myself and it took me less than one hour in my garage for the front and rear cameras from Suncoast. The hardest part was finding the yellow connector under the front headliner. I also installed a wiretap for my Uniden R8 at the same time. Bring me your car and 12 cans of decent beer.
Ricky Bobby (03-31-2024)
#269
X040660 (09-13-2023)
#270
@Vivienne @X040660 , there is an updated Technical Service Bulletin from Porsche (see attached PDF) that the dealers either don't know about, or are ignoring in order to charge you more. It specifically says 1.9 hours for a Coupe (front + rear) so having this with you or sending it to their service department should help.
