Preparation for Porsche Dashcam (Front and Rear)
#46
It specifically says FRONT preparation
The US build spec is $130 for "Preparation for Porsche Dashcam (Front) Porsche Exclusive Manufaktur - Pre-wiring for Porsche Dashcam (front), which is available separately via Tequipment."
#47
To me, one other benefit to the pre-wiring is that you don't have to start removing a whole bunch of parts just to run the wiring. The fewer parts to remove the better. Maybe it is just my luck but interior trim pieces removed and then installed never seem to go back correctly and there is always some gap or squeak that arises. I have the pre-wiring specified on my Targa 4S (now if I can just get an allocation - over one year waiting and counting).
pkalhan (11-24-2022)
#48
#50
Picked up my 2023 cabriolet this afternoon.
I specified dash cam prewiring.
There is NO connector or cable that is openly accessible at the rear view mirror - which is where the dash would be located.
When i get a chance I will remove the overhead courtesy light panel - I'm pretty confident the OEM dash cam wiring harness will appear behind this panel.
“I spoke with our Porsche Tech about the wiring for the dashcam. It appears according to the Tequipment instructions to be on the right side (direction of travel) running down the A-pillar.”
Here is a link to the discussion on the 718 forum with some pictures I took:
https://rennlist.com/forums/718-gts-...sh-camera.html
I have not disassembled the A-pillar yet.
One might guess the 911 and 718 might be similar, then maybe not.
#51
I specced this option, but am having second thoughts. Fine print on the suncoast listing:
Suncoast Note: For cars with wireless Apple CarPlay, you lose wireless capability when using the Dash Cam. You will have to connect your phone via cable while using the Dash Cam.
#52
#53
Hopefully only if you are trying to download videos or otherwise control the Dashcam from your phone. The phone connects to the Dashcam using wifi, so you can't be on wireless CarPlay at the time. If this is a constant limitation then may as well just get an aftermarket Dashcam.
#54
Service asking for 5 hours to install a dash cam on pre wired 911 Cab MY23’ which is well over $1,000. Doesn’t make sense!
Did anyone had it installed on prewired 911 MY23?
The following 2 users liked this post by jplaro:
EXFIB (12-21-2022),
porschedood5000 (09-04-2023)
#56
I just got my 992,with dash cam preparation, I do not see any wires or connector anywhere. I guess you still have to remove the internal light console and the connector for the dash cam will be there behind it. If someone ventures there , take a pic for the rest of us.
#57
#58
Received 4,067 Likes
Looks like I will need to uncheck that box then, as I was only after the added wiring to the rear view mirror area.
balucipher (11-29-2022)
#59
