992 GTS Lightweight Package
#61
I considered the lightweight package for a bit but then opted to the just spec the LWB. I didn't care much for RAS and was weary of the lightweight glass and battery. I wanted the PCCBs but just couldn't get myself to tick that box. I wanna think that most of the weight savings in the lightweight package are related to seats (?) someone correct me if I'm wrong. So I have 1/2lightweight package option .
johny221 (12-10-2022)
#62
Reading some of the comments on this thread makes me think that the 911 owners on here only think that something is worth it to pay more if it is a completely different car. Get the lightweight package! The car will be faster in the straights and on the track. The feedback as a driver feels very good with the light weight package. As someone who tracks their cars, my laps times are about 2 seconds slower with a passenger in the car.
Car and driver was able to get a 9.9 second 1/4 mile in the lightweight package turbo S. The reason being is that the lightweight package saves a lot more than 50 pounds or whatever Porsche claims. There is a thread on the 991 forum of an owner removing the rear seats and the rear seats alone weighed 20 LBS (not including seat belts). The buckets vs 18 ways is at least a 40 lb weight saving (both seats added up). Then you add 8 lbs for lightweight glass + the sound deadening material taken out, the real weight saving is probably about 70-75 lbs.
but this forum is rampant with 992 CS and base owners telling themselves that their cheaper optioned car is “all they need” and that any further options that are out of their price range “are not worth it and you won’t feel it”.
get the lightweight package. I optioned it on my GTS
james6speed (01-15-2023)
#63
Agree, especially that RAS adds weight back on, leading to the lightweight battery.
Ideally, lightweight package should have been bucket seats and rear seat delete, PCCB, CF roof (minimal weight loss I know), lightweight battery, lightweight glass, some lightweight wheel options and an akra exhaust (one can only wish). It would cost a an arm and a leg, but what doesn't lately
#64
balucipher (12-11-2022)
#65
#66
#67
#69
Plus suspension is much stiffer compare to Base or S (there is a table with all the 911 suspensions loads, GTS same as Turbo S and much stiffer then rest)
911Stiller (12-14-2022)
#70
hi Stiller, the way I understand it, SPASM drops -10mm compare to base Carrera, but GTS oem (except Targa) will drop -20mm compare to base (-10mm compare to S with SPASM). And when selected free options SPASM in configuration, this will actually bring GTS +10mm up, e.g. only -10mm compare to base, or same as S with SPASM.
Because from what I gather, the turbo Sport-PASM that is standard on the GTS lowers the ride height by 10mm vs the standard Carrera PASM suspension, so same ride height as a Carrera-S with Sport-PASM, while the optional non-Sport-PASM on the GTS is the same as the Carrera-S base suspension.
#71
Are you sure about that?
#72
Are the carbon buckets on stop build right now?
#74
I have a request for allocation currently waiting for a GTS and have time to make changes.
#75
Is it worth having the lightweight glass? It sometimes breaks a for no apparent reason. We have the same glass on a Taycan and the whole back window shattered recently while driving down the road. The SA told me they see a lot of this happening.
