Disabling the rear spoiler
#46
Thank you - when you say "either up or down" do you mean that the 9 different values are like 10% raised, 20% raised, 30% raised, etc.
Or do you mean that at each speed it's either all the way UP or all the way down?
I will be speaking to a shop soon, but wanted to get some real world experience on here, to see what those independent shops/dealers may say![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
#47
I'd like to know as well as I'd prefer the spoiler to stay down ALL the time...even at speed. You might have to pull the motors or disconnect the harness that powers it up and down. But I would think you would get all kinds of CEL and errors if you do that.
If you figure it out let us know!
Do you have to? It’s just the process that is recommended.
mattchow (04-12-2022)
#50
dbtran (04-13-2022)
#51
#52
Only way to disable is with a PIWIS III from the dealer or someone local that will let you use it. You can only code it out so if you need to do any work to the lower bumper area then you would have to code it back in and then out again.
#53
i will take it to the dealer but i would like to give them some ideas, i think i did not understand well, you mean they have to code the tail to be deployed but in reality it will be in and not deployed ? Thanks!
#54
They will code off the active function as if you have a fixed spoiler.
#55
I installed the Future Design fixed duckbill on my 23 Carrera T. The dealership said they will no longer code out spoilers. A local tuner said that the car is too new for him to update and Porsche hasn’t released the updates he needs yet.
I thought about pulling the fuse but it’s in the rear fuse box which is not easily accessible.
Anyone having luck getting this done on their 23 or newer 992?
#56
#57
The following 2 users liked this post by rnlst_log:
AlterZgo (03-15-2024),
Schwarz992C4S (03-16-2024)
#59
