After market exhaust for novices
Old 12-15-2020, 06:25 PM
Tupper
Tupper's Avatar
Received 1,615 Likes on 819 Posts
Default After market exhaust for novices
Hi all, on Rennlist there looks like there are lots of people who've owned several 911's and other sports cars on here.
There are also so many brands of after market exhausts out there that it's sort of intimidating for the uninitiated.
For myself, my default is to obviously do no harm to my beautiful new car. But I am tiptoeing around the idea of enhancing the sound of my car.
Can somebody recommend which brands are best, which produce the best sound, without creating headaches for a busy, uninitiated and non-handy guy like myself? I don't want to fail emissions tests, have error messages, etc.
If anybody can share their recommendations, it would be vastly appreciated. Thanks
Old 12-15-2020, 06:37 PM
Staff@WORLD
Basic Sponsor
Staff@WORLD's Avatar
The Akrapovic is probably the nicest one available with the best increase in sound. It's also made out of titanium so it is a lot lighter than the factory exhaust which is always an added benefit. The car will have no problem passing emissions and the warranty of the car will not be affected.
If you wanted to increase the sound further you can add a set of high flow sport cats from Soul as well.
If you have any other question feel free to reach out to me.
-Craig
WORLD MOTORSPORTS
2170 W 190th Street Torrance, CA 90504
(310) 533-8900
- Akrapovic - BMC - TechArt - H&R - By Design - AMS - CSF - Kline - NGK - TiLugs - HRE - M Engineering - ID Injectors -
FULL SERVICE INSTALLATION FACILITY - STATE OF THE ART WIND TUNNEL DYNO - ECU TUNING
WORLD-MOTORSPORTS.COM
drgav2005 (12-26-2020)
Old 12-15-2020, 06:53 PM
Tupper
Tupper's Avatar
^ Thanks.
So what happens when you replace the "cat" (catalytic converter I'm guessing) versus simply replacing the exhaust.
Why do people replace cats? What does one gain from doing that versus simply replacing the exhaust?
Old 12-15-2020, 07:03 PM
smartbot
smartbot's Avatar
^ Thanks.
Replacing the Cats with Sport Cats (usually 200 cell) really is the best option. If you already have Porsche Sport Exhaust it makes the most sense. It give you more sound without a lot of hassle (it's a simple swap of the cats). I went with the Fabspeed 200 cell cats: https://www.fabspeed.com/porsche-992...nverters-2020/
​​​​​​​Check out my thread here:https://rennlist.com/forums/992/1184943-fabspeed-sport-cats-just-installed.html
Old 12-15-2020, 08:07 PM
BIGWORM
BIGWORM's Avatar
Received 1,061 Likes on 533 Posts
^ Thanks.
I think you see more sport cat sales than exhausts sales is because most people have the PSE exhaust. And those who do not the have the PSE seem to buy the exhaust. Plus sport cats where very popular on the 991.2 generation.
Sport cats can be had for 1600 used and up to 3K new. They make your turbos much louder and where very popular on the 991.2 911 with PSE. Many of us got the 992 sport cats expecting sound increases to be like they where on the 991.2 and that was not exactly the case. They DO make your turbos induction noises much louder. And the overall exhaust is louder. But not like it was on the 991.2.
Heres what you hear with sport cats at low speeds. Mucho turbo whistle. I actually love hearing them talk to me.
https://www.youtube.com/watch?v=AfpN...ature=youtu.be
Old 12-15-2020, 10:21 PM
Tupper
Tupper's Avatar
Thanks guys.
So I have the PSE.
It sounds like you guys are suggesting that I keep that and replace the cats.
So now it’s about choosing the best one. If I’m going to spend the money, I guess I’d like there to be a noticeable difference in sound. Do the various brands (Fabspeed, Aprakovic, etc) differ by much or is the ultimate sound pretty much the same for all of them?
Old 12-15-2020, 10:59 PM
Pad Bender
Pad Bender's Avatar
Received 1,295 Likes on 654 Posts
This is how I understand it...(please others correct me if I'm off)
Catless Downpipes - most power gains / raw and loud engine sound / check engine light and warranty considerations / maintain stock valve function
Sport Cat Downpipes - modest power gains / increased engine sound / no check engine and maybe warranty considerations / maintain stock valve function
Muffler deletes/x-pipes/other muffler designs - minimal power gains / signature exhaust sound / no check engine and no real warranty considerations / aftermarket valve solution
Some put it all together nicely. Most, if not all do parts or will build you a solution with unique sound qualities. Reputable manufacturers have good fit, finish and durability.
It gets expensive when you go into weight saving/heat resistant/resonant metals like Titanium and Iconel but that's where the glory is had.
dashanin (01-03-2021)
Old 12-16-2020, 12:32 AM
ipse dixit
ipse dixit's Avatar
Received 11,954 Likes on 5,212 Posts
Stay OEM
The following 2 users liked this post by ipse dixit:
Bluehighways (12-17-2020), Overdraft (12-26-2020)
Old 12-16-2020, 01:35 AM
ryanlsmith
ryanlsmith's Avatar
Some use the stock actuators which results in OEM like behavior (setting aside the sound differences).
Old 12-16-2020, 08:03 AM
Penn4S
Penn4S's Avatar
Received 1,349 Likes on 759 Posts
If you want a noticeable difference in sound I don’t feel cats alone will do that. If you already have PSE and you want more aggressive sound then a system change is best. Kline is a great exhaust with great build quality and beautiful workmanship. Many on RL have or have had Kline and can speak to its merits.. I had the Kline Iconel on a previous 4S of mine. Kline is not the only high quality after market exhaust but it is high quality, still affordable (in relative terms) and has little to no drone and is an easy remove and replace install.
Very few options are cheap and if they are they aren’t worth getting in the long run. Be wary of any exhaust that has drone as many after market do and they are migraine makers and intolerable for long periods of time to drive.
Search as there are many threads on exhausts by those happy and unhappy. In the end they cost significant $’s even the worst ones so be patience and try to hear them if possible as buying and replacing are more $’s.
NigelPlays (01-18-2021)
Old 12-16-2020, 10:17 AM
ryandarr1979
ryandarr1979's Avatar
I’ve found that for the best change in sound, you also want to consider materials used as well as valve actuation. Akropovic uses titanium. Kline has inconel, Quicksilver uses stainless and titanium. Tubi uses stainless. Expect to also pay a premium for material and valve design. Sport cats, to Big Perm’s point, really just amplify turbo induction noise more so than just make the exhaust louder. I’m really hoping the Kline exhaust in the 992 sounds as good as the Kline exhaust in the 991.2.
Old 12-16-2020, 10:31 AM
flsupraguy
flsupraguy's Avatar
Received 1,506 Likes on 810 Posts
Out of all the videos I've seen the quicksilver sounds the most "NA" compared to the others. This isn't saying much as they all likely sound different in person...
Old 12-16-2020, 12:59 PM
Pad Bender
Pad Bender's Avatar
Originally Posted by flsupraguy
Out of all the videos I've seen the quicksilver sounds the most "NA" compared to the others. This isn't saying much as they all likely sound different in person... https://youtu.be/le7ZlPHvRAs
Sounds great with the GPF and keeps dash valve control....ideal.
Quicksilver on the 991.2 turbo was vicious...TGEs brother had it I believe.
Old 12-16-2020, 08:24 PM
Tupper
Tupper's Avatar
I want my car to sound like this. This. Is. Bad *** perfection:
ribold01 (01-03-2021)
Old 12-16-2020, 08:28 PM
peterdouglas
peterdouglas's Avatar
Default 992 TURBO S ??
Information/timetable, please’
Quick Reply: After market exhaust for novices
