Battery Tender - UNSOLVED
Old 01-18-2021, 06:45 PM
  #46
deeare7
6th Gear
deeare7's Avatar
Would somebody kindly take a picture of their eyelet setup please?
The negative mass post of the car (if I understand the term correctly - what the owners manual suggests using as the negative ground attachment) is a good 2-2.5 feet away from the battery (much too far for the eyelet to reach).
Old 01-18-2021, 07:12 PM
  #47
dgtarga
dgtarga's Avatar
You're correct. I used an alternative connection to the frame for the ground wire. Then ran wires out under the front of the cover. Works just fine....
The following 4 users liked this post by dgtarga:
997usa (01-18-2021), bobblehead (01-18-2021), deeare7 (01-18-2021), markjeansonne (01-20-2021)
Old 01-18-2021, 08:22 PM
  #48
malibu515
malibu515's Avatar
Thats exactly what I did. If you want to store the car for a few days or a long time, it makes sense to plug it in. This way it is no hassle.
Old 01-19-2021, 03:55 AM
  #49
Joan Alcover
Joan Alcover's Avatar
CTEK Comfort Connect Eyelet indeed only 15.7 inches long
https://cdn.shopify.com/s/files/1/01...f?v=1598460994
But CTEK Comfort Indicator Clamp 59 inches long
Use the latter, remove the clamps and replace them with eyelets.
KLOC (03-25-2022)
Quick Reply: Battery Tender - UNSOLVED
