Coding 992
Old Oct 21, 2025 | 05:21 PM
  #991
M3Inline6's Avatar
M3Inline6
Originally Posted by siberian
In PIWIS 3 there is a P mode or Production mode that I believe is used to test or fine tune modules. From all who've tinkered with PIWIS the consensus is you should mostly work in V (or dealer) Mode and occasionally in E or Engineering mode. Never in P mode.
Having always heeded Mars' advice I never delved there.
siberian
Ahhhh ok. I know there are changes among versions. PIWIS 4 is definitely set up differently.
Old Oct 21, 2025 | 05:28 PM
  #992
simhoppm's Avatar
simhoppm
If you have PIWIS 4, could you navigate to DME (or ECM, seems Porsche is not consistent with their terms) and see if there are any menu concerning start/stop ? for 992.1
Old Oct 21, 2025 | 05:46 PM
  #993
M3Inline6's Avatar
M3Inline6
I’m not home at the moment, but like @siberian said, *** is mentioned in and has parameters in so many different modules. I can check for you when I get back from my mini road trip. I’m a relative newbie to PIWIS use having only used it to code the AeroKit, euro taillights, etc., so if the veteran users couldn’t figure it out, I won’t be of much help.
Old Oct 21, 2025 | 08:43 PM
  #994
Shogunade's Avatar
Shogunade
For those of you who programmed remote windows up and down, were you able to retain the lock chirp sound?
Old Oct 21, 2025 | 11:41 PM
  #995
M3Inline6's Avatar
M3Inline6
My lock chirp behaves intermittently. It’s kind of annoying because I like the audible confirmation.
Old Oct 22, 2025 | 12:04 AM
  #996
Andy Liu's Avatar
Andy Liu
The start and stop is hard code. There is one that say activating start and stop which you can change, but setting it from last known will not work. You will need to get the car tune and ask your tuner to change it as it is hard coded in the DME
Old Oct 22, 2025 | 12:05 AM
  #997
Andy Liu's Avatar
Andy Liu
Right now I am trying to get the shift light to work on the a 992. I got it to show up in the cluster but it doesn't do anything. So right now there got to be a way to adjust the RPM down as the shift light only work at 6500 on the GT3
Old Oct 22, 2025 | 12:20 AM
  #998
REVS11's Avatar
REVS11
Has anyone found if there's a setting for brake system type? There should be some setting for different sizing, wondering if PCCB is also an option in there.
Old Oct 22, 2025 | 12:32 AM
  #999
Andy Liu's Avatar
Andy Liu
i think it is mechanical thou isn't it? I am upgrading my brake to brembo bbk on my 992 with 6 pot front and 4 pot rear and bigger rotors
Old Oct 22, 2025 | 12:59 AM
  #1000
REVS11's Avatar
REVS11
Sure. What I meant is that the ABS and PSM may be calibrated differently for each brake system. There's no way for the car to know you changed the brake hardware if you don't update the coding.
Old Oct 26, 2025 | 02:30 AM
  #1001
REVS11's Avatar
REVS11
Found the answer to my own question, this document shows the coding for PCCB retrofit (calls out 992 GT3 - unclear what the difference might be - use at own risk).
File Type: pdf
Old Oct 29, 2025 | 01:46 AM
  #1002
bobveznat's Avatar
bobveznat
5th Gear
Hi everyone, long time lurker first time poster. Thank you for this and all the other related threads, they have me, at least, inspired to the tune of buying everything including one of these awesome 120A power supplies.
I've got piwis 41.500 + diag 38.250 up and running and talking to my 2025 992.1 Turbo S. Things more or less seem to be working fine until I get to the F7 - Add. Menu area. Once that loads up everything is listed under value group "PR Numbers" and the coding values (e.g. 0P9) are all enumerated there except that they are all "unknown I-no.". If I go scrolling for the control values related to matrix headlights I can see the expected US values. But, unlike in simulation mode, there's no dropdown menu. It's as though piwis has no idea what these coding values are and especially what the options might be.
The piwis image I have was originally in E mode. I switched it to P mode and started getting prompted to create a val. I said yes to this but after ~30 minutes being hung on, iiirc, "finalizing report" I gave up and aborted it (which also hung and I simply rebooted everything).
Is this as simple as not having a new enough version of piwis? Or have I missed a step somewhere?
Old Oct 29, 2025 | 01:53 AM
  #1003
Andy Liu's Avatar
Andy Liu
if it is 2025 which is a 992.2 it won’t work with this. If it is a 992.1 then you need verison 42.950 which this free verison won’t work
Old Oct 29, 2025 | 02:24 AM
  #1004
bobveznat's Avatar
bobveznat
5th Gear
It's a 2025 but still 992.1 (delivered in July, 2025). Is it possible to get 42.950 outside of mhh auto?
Old Oct 29, 2025 | 02:38 AM
  #1005
M3Inline6's Avatar
M3Inline6
Yes! I have 42.950 as well, and I didn’t get it from MHH auto.
