Coding 992
Old Sep 26, 2024 | 08:44 AM
  #736
Norton34's Avatar
Norton34
Originally Posted by sitetech
I just disabled startstop function completely by edit manually DME software. Now I have not even this button on pcm screen.
Could you please share how you did it if you can. Using piwis? It's kinda hard to believe or maybe you got some newer MY that allows for these changes to be persistant.
I even asked the guys on russian piwis telegram channel, but also no working solution ))
All the options commonly mentioned here (DME codes editing or even gateway (stop prohibition)) are resulting in car restoring codes back to default on the next start. At least in my MY20. I tried doing that using Launch X431 and PIWIS 3.
Old Sep 26, 2024 | 11:13 AM
  #737
Marcus13190's Avatar
Marcus13190
Hi guys, i've Panamera 970 my 2012 and i want to know if it's possible have PSE active when the sport button is active ?
Marc
Old Sep 26, 2024 | 09:49 PM
  #738
siberian's Avatar
siberian
Bump, please share if this was done.
siberian
Old Sep 27, 2024 | 10:57 AM
  #739
traju's Avatar
traju
Originally Posted by Shogunade
Thanks! But I only changed the 3 to 5 and clicked write. No dice. I'll try again with your advice then going back to see if it saved. @rnlst_log Any advice? Thanks.
I have the same “issue”. Looks like newer 911s have some modules write protected by SFD2.
Mars was able to help me code matrix headlights but similarly like you, I can’t change this option for example.
You can run logging and then see if you see checksum error when writing.
Old Sep 28, 2024 | 10:38 PM
  #740
siberian's Avatar
siberian
@sitetech can you please share how you deleted *** please? Thanks
siberian
Old Sep 29, 2024 | 12:33 AM
  #741
718socal's Avatar
718socal
Originally Posted by AlfaM5
I didn't have problem changing that value. Just make sure you write the 5, then click the mouse on any empty area and then save.
Just curious. Which adapter are you all using? I am using the T6PT3G.
Old Sep 29, 2024 | 03:45 AM
  #742
sitetech's Avatar
sitetech
siberian
1. Do virtual read of ECU software with equipment like Flex, Autotuner, bFlash, CMD, etc. You will get a bin file.
2. find and buy the DAMOS file for your engine
3. Find switches for *** and change them with software like WinOLS
4. Write this file back to your ECU
5. Done.
If you can do the first step, then I can do steps 2-3 for you (PM)
Same way i tuned my exhaust flaps positions, slightly drop down cooling temperature, adjust a cold start.
Old Sep 30, 2024 | 02:47 AM
  #743
mrsarden's Avatar
mrsarden
Hi guys, I need help with activating wireless carplay using piwis. When i code the wifi to be active, 2 notifications keeps popping up about wifi being available and not available.
The video is in the attachment. Have anyone have experienced this before?
Thanks in advance
File Type: mov
Old Sep 30, 2024 | 07:58 PM
  #744
Norton34's Avatar
Norton34
Thanks in advance
You seem to have PCM 6. Isn't it standard for PCM 6 to have wireless carplay? with no coding changes required
Old Sep 30, 2024 | 08:04 PM
  #745
M3Inline6's Avatar
M3Inline6
Yes! My PCM 6 has wireless CarPlay natively.
Old Sep 30, 2024 | 11:44 PM
  #746
mrsarden's Avatar
mrsarden
In Indonesia porsche deactivate wifi function for of their cars. Hence we gotta activate it ourselves via piwis.
Old Oct 1, 2024 | 03:11 PM
  #747
AlfaM5's Avatar
AlfaM5
Haven't done it so I don't know the steps but Carplay is in the MIB2 module.
Here are the steps from a 2019 Cayenne:
MIB2 (Zentralrechner) --> Manual Coding without rules --> Vehicle Configuration --> Bitfield (7) Apple_DIO_Wireless: On and Bitfield (5) wlan_5ghz_switch: On
Old Oct 2, 2024 | 12:41 PM
  #748
JUN6817's Avatar
JUN6817
In my 2023 992,
I can't look for under MIB2 in PCM6...
so can't change..
please teach me to activate wireless carplay in PCM6 .
Old Oct 2, 2024 | 01:48 PM
  #749
adrianp89's Avatar
adrianp89
Anyone have any luck adjusting the rules for memory seats?
Old Oct 4, 2024 | 02:44 AM
  #750
nicksnicks's Avatar
nicksnicks
Originally Posted by JUN6817
In my 2023 992,
so can't change..
Is your vehicle equipped with Carplay? As far as I know, the Carplay of MIB3 vehicles is controlled by the gateway module. If you want to activate Carplay, it is impossible to achieve it from coding. You need to crack the gateway and write the FOD code.
