Coding 992
Old Sep 16, 2024 | 01:28 PM
  #706
J Irwan's Avatar
J Irwan
What does one have to do with the other? The “mode” is irrelevant. The driving behavior is what is relevant.
In manual transmission i agree its irrelevant, but for PDK i believe sport and sportplus keep the rev/rpm higher on each gear so that you are always on-boost.
In manual transmission is our right foot the keep the rev on-boost
Old Sep 16, 2024 | 03:55 PM
  #707
jlegelis's Avatar
jlegelis
Thats is an illogical statement. While a PDK will shift at higher rpms in sport mode, the engine speed itself is commanded by your right foot, as in MT, and has nothing to do with ‘mode’. Avoiding high engine speed and increased engine load (hence demand for more power / boost) is accomplished by easier application of the throttle in any mode, regardless of gearbox.
Old Sep 16, 2024 | 04:53 PM
  #708
VarTheVar's Avatar
VarTheVar
It's relevant because sport mode opens up the air ducts to the heat exchangers and prevents the oil from warming up as quickly as possible. I generally drive in normal mode until oil temp is up to ~160
Old Sep 16, 2024 | 05:35 PM
  #709
eagle1960's Avatar
eagle1960
Originally Posted by nick_broccoli
Question for you all. I wasn't sure where else to ask and wasn't sure if this was new thread worthy.
I just put a valved catback on my 24 C2S and I am getting a cell for the exhaust valve position. the valves when "off" are fully open like they should be stock. I am assuming the diameter or angle of the pipe on the aftermarket catback is slightly different. I have the Cargraphic controller and when set to follow the OEM valve programming the valves keep cycling to test open/close. It did not act this way with the controller on the stock exhaust. I know the valve can be re-learned at the dealer and that's not an issue if I have to go to the dealer... but I have access to an Autel MaxiPRO MP900-BT with the latest Porsche update from them. I was wondering if any of you knew if it was possible to do the relearn with this or a similar tool. I searched through the different modules and menus on the device, but nothing stood out for the exhaust. I haven't been able to find anything via Google either.
Thanks for your time,
Nick
You have mis-installed the actuator(s). The system looks for the valves to be OPEN when the ignition is off. If you install the one or both of the valves so it is closed, you will get cycling. Do- over time.
Old Sep 17, 2024 | 03:55 AM
  #710
sitetech's Avatar
sitetech
Shiftpoints are higher in sport mode. So engine will work at higher rpm until geabox will switch a gear. Even at small foot pressure.
Old Sep 17, 2024 | 12:54 PM
  #711
Mike818's Avatar
Mike818
Pretend like you actually enjoy driving your sports car and manually shift your automatic..... Problem solved. I never drive my dual-clutch evo in automatic, and in that platform it is advised to always have it in "Super-Sport", which I'm guessing would be sport+ in Porsche, because the higher clamp pressure on the clutches reduces wear. No idea if that translates to Porsche but I wouldn't be surprised.
Old Sep 17, 2024 | 07:49 PM
  #712
jlegelis's Avatar
jlegelis
Yep, PDK in Sport+ and ‘manual’ mode is the 992 party trick imho! Definitely ups the ‘engagement’ in a big way without a fiddly third pedal when in traffic. All the ‘never PDK’ crowd should give it a whirl before deciding…
Old Sep 17, 2024 | 09:00 PM
  #713
M3Inline6's Avatar
M3Inline6
Neither of those points matter. Drive reasonably until the car heats up. The mode is irrelevant.
Old Sep 17, 2024 | 10:31 PM
  #714
VarTheVar's Avatar
VarTheVar
Ok boss
Old Sep 18, 2024 | 01:21 AM
  #715
doctorocho's Avatar
doctorocho
Are the 992.2 standard headlights the LED Matrix?
Old Sep 19, 2024 | 05:11 PM
  #716
sitetech's Avatar
sitetech
Has anyone coded tire temperature display?
Old Sep 19, 2024 | 05:13 PM
  #717
sitetech's Avatar
sitetech
I tested yesterday. Hold the gas pedal on same position and car keep 3000rpm on same gear. So your advice does not work.
Old Sep 19, 2024 | 05:16 PM
  #718
sitetech's Avatar
sitetech
@sitetech using PIWIS, in Kombi, enable (I think):Werkseinstellung Menükonfiguration Performance
and
Weitere Kodierungen III Performance Monitor Einheit Leistung
It will then appear as menu option in PCM which you can enable to show on the right screen of the dashboard. Unfortunately no data is displayed, and I've not been able to find a DME (or other controller) setting that 'produces' the data. @John Mclane was successful on his '20, but I've never seen it done successfully enabled on other non-GT 992. Please share any discoveries you may unlock.
Yes, got same result. No data unfortunately
Old Sep 19, 2024 | 05:52 PM
  #719
zachr's Avatar
zachr
3000rpm with minimal load isn't going to hurt anything dude
Old Sep 19, 2024 | 05:56 PM
  #720
CurryPuff's Avatar
CurryPuff
and
What car you do have? My '24 GTS hows the graphs for power and torque and works just fine. I didn't have to code anything on it.
