Sport design Front Lip
#76
A lot of the discussion surrounding the need for FAL suggests that one of the reasons that it's not worth the price is that the front bumper lip is cheap and easy to replace if damaged... However, in reading through this thread it seems to me that if the car has the Aerokit front bumper, the lip is not cheap nor simple to find in matte black. From the Suncoast website I found: https://www.suncoastparts.com/produc...92aerolip.html which is $725 and comes with primer only, so more when painted/wrapped. It would be another $700 if the other (lower) lip piece is necessary. I'm trying to make the final call on FAL for my T allocation (SPASM), and looking into this has tilted me towards FAL. Curious as to what others with the Aerokit think about FAL.
aways (03-23-2024)
#77
It really does depend on where you live. That is one of the reasons for the varying opinions on this forum. People who say FAL is not necessarily probably do not have to negotiate sharp inclines where they live.
Consider your own drive way, the entry/exit where you work, and consider places where you visit. If the ramps are moderate, you can probably get away without FAL.
I’ve posted previously, based on replacing the unpainted (extended) sport lip, you would need to do ~3.5 replacements to equal the cost of FAL. If you expect to replace the lip at least once per year, and you plan on keeping your car more than four years, FAL pays for itself.
aways (03-23-2024)
#78
#79
Also, I'm still a bit confused about whether there's a difference between the Sport design front lip and the Aerokit front lip (the Porsche configurator videos seem to look different). […] it would also matter how much more extended the Aerokit lip will be compared with standard bumper lip.
Unfortunately, the Configurator is not very clear on the differences between the spoiler lip included in the Sport PASM option and the Sport Design option, other than the Sport Design Option gives you a painted front spoiler. Both have an extended lip that reduces approach and departure angles, and this leads me to believe they are the same spoiler (just in different colors).
#80
There was a thread here on RL about the differences between the various front spoilers on the 992. If I find it, I’ll share the link.
#81
Humm… They do look a little different in the Configurator, if you zoom in.
Standard front spoiler lip (unpainted).
Sport PASM front spoiler lip (extended, unpainted).
Sport Design without Sport PASM front spoiler lip (extended, painted). (This looks the same if you add the Sport PASM option; see below).
Sport Design with Sport PASM front spoiler lip (extended, painted). (This looks the same if you don’t add the Sport PASM option; see above).
#82
Thanks for that info. I also noticed that for the Aerokit specifically it says: "Note: Significantly reduced approach and departure angles.", which makes it seem that the Aerokit is somewhat different than the Sport design where it says "SportDesign Package reduces approach and departure angles." Maybe I'm over-interpreting the descriptions, but it seems that by including "significantly" maybe the Aerokit lip is even more extended...
#84
Thanks. I'm pretty sure I can live without FAL in my area by being extra careful, but there are definitely some places nearby where it would be required to avoid scraping. it seems like such a nice option (especially the GPS memory functionality) that I'm tempted to go for it. Also, I'm still a bit confused about whether there's a difference between the Sport design front lip and the Aerokit front lip (the Porsche configurator videos seem to look different). It would also be nice if the replacement lips came painted in matte black rather than grey primer. Finally, in addition to the ride height considerations (I don't plan to go any lower than the SPASM -10mm), it would also matter how much more extended the Aerokit lip will be compared with standard bumper lip.
Did you even read this thread????? I literally outlined the differences and posted photographs. Everything you need to know is in this thread, you need only read it. There is absolutely a difference between the two lips and the two black underspoilers.
Post #63 and Post #70.
#85
M3Inline6 (03-24-2024)
#86
Yes, thank you. I was thrown off by reading another thread then coming back to this one, and then by the Suncoast parts website (https://www.suncoastparts.com/produc...92aerolip.html) which seemed to imply that the SportDesign and the Aerokit lips were the same. Anyway, thanks again for your help. Much appreciated!
Any time! Clearing up any confusion was the objective.
#87
Apologies in advance so for Sport Design, is the part number for the matte black one 992-807-100-G-OK1?
Suncoasts website is a bit confusing in that they lump GTS, sport design, and aero kit as one. The one I was trying to avoid is the primer grey one.
#88
M3Inline6 (04-12-2024)
#89
#90
