so the spasm lip and sport design lip are the same? looks so much smaller when painted.
There are different part numbers depending on the bumper you have. The base bumper has two different lips; the lip for the Sport Design bumper is the same regardless of whether or not you have SPASM, but the GTS is optioned with the matte black version.
The base bumper and the Sport Design bumper have different lips.
The base bumper it self has 2 different lip variants. The standard one, and the sportier version that was quoted here with part # 992-807-100-B-OK1
Part # 992-807-100-L-OK1 is not a replacement lip, but an underneath protective moulding.
The 992 SportDesign front bumper lip is part # 992-807-100-F-G2X (if primed) or 992-807-100-G-OK1 (when matt black)
The former it’s the one that’s been available from Porsche since 2019 for the 992 with SD package, the latter is the one specific to the GTS that started this thread
Bumping this - with the GTS now out in the while, has anyone found the part number for the matte black front lip on the front SportDesign bumper? It is NOT 992-807-100-G-OK1, that is one of the support pieces, I have confirmed this with multiple dealers who have tried to order the part for me.
Is there a separate part number for the Aerokit front lip on the GTS? The configurator seems to show that the front lip is different on the Aerokit compared with the one on the sport design bumper. Both in the images highlighting the portions that are modified with the kit, and in the scrolling left to right changes images (see below). Note that this is on a GTS, as evidenced by the CL wheels, etc.
Just wanted to bump this. Has anyone figured out the part # for the GTS black lip for the sport design bumper?
Multiple dealers have told me that they only see this coming primered from Porsche based on the parts system, so I am confused as to what happens if this needs replacing on a GTS.
Exactly my thought. Seems like a common part that would get replaced too.
On the 991.2 GTS models, they typically arrived in black plastic, but replacements were only available as primered for paint. This upset a lot of us over there, who preferred the matte plastic.
FWIW, black Plastidip VERY closely matches the color and texture of unpainted black Porsche body panels.
Pic below shows Plastidipped front lip on 997.2 GTS, with unpainted side skirts (the car came originally with painted front lip and these unpainted skirts).
Agree on the painted front lip not working as well on the 992, so I removed mine (x6 bolts), slipped off easily and wrapped with 3M 2080 satin silk wrap - which is a very close match to the original plastic:
Are the 6 bolts Philips screws? Also, was this doable without lifting the car?
these are the parts that came with the aero kit I purchased for reference primed lower lip primed lower lip part # underneath lip underneath lip part #
There are definitely some discrepancies with the front lips. My 2022 Sport Design front lip - which is supposed to be the same as the AeroKit front lip - did not come with the black plastic lower spoiler seen on some of the AeroKit cars (..see attached image).
In looking around online, it seems as though the extra lower black addition should’ve been on my car as well, but it’s definitely not there as seen in the photos of my car below.
This earlier AeroKit car doesn’t have it either, so it much be a more recent change or maybe Porsche uses different parts:
