Radiator Screens
#62
Agreed would be awesome if you could share just a bit more info when you have time. Don’t have my car yet so hard to tell from pics how you got it all attached and don’t have a car to walk out in the garage to reference. But definitely want to do this or something similar once my 992 arrives.
#64
I made eight (8) 2.8 to 3-inch diameter cylinders, four (4) for each side, in order to completely fill out the width of each condenser/radiator opening. First I cut off eight (8) lengths of mesh from the roll about 9.5 inches long each. Next I rolled each mesh section such that it forms a cylinder that is 6 inches tall by 2.8 to 3 inches in diameter. To maintain the cylindrical shape I secured the ends of the mesh together with small zip ties located at the the top, middle and bottom. See pic.
Lastly, I squeeze each cylinder so that they can be inserted between the louvers located in front of the condenser and radiator. Once the cylinder is behind the louvers, I simply rotated it upright such that its longitudinal axis in perpendicular to the ground. I repeated this four (4) times per side. I feel that the cylinders are trapped sufficiently at each end by the plastic bulkheads that surround the condenser/radiator, hence there is no need to tie them together.
Hope this helps.
Jason
#65
For the materials I purchased plastic Gutter Guard mesh material from Ace Hardware. It comes in a 20-foot roll by 6 inches wide. I also purchased a bag of small nylon zip ties that are suitable for outdoor use. See pic below of the mesh material.
Hope this helps.
Jason
Hope this helps.
Jason
#66
Always mystified to see how frugal owners can be with a $150k car… from Home Depot bins for the frunk, to eBay keys… now we have Ace hardware plastic gutter guards… 🤦🏼♂️
blk_c2s (03-13-2023)
#67
The following 10 users liked this post by turbonator:
brandobot (04-30-2024),
eagle1960 (11-23-2021),
GTS2022 (03-22-2023),
Guzzgreg (03-23-2023),
icanthelpit (11-22-2021),
and 5 others liked this post.
#68
Jason
The following 12 users liked this post by BOPE:
Bluehighways (11-22-2021),
defiant2 (12-04-2023),
Fullyield (03-14-2023),
and 7 others liked this post.
#69
Maybe you guys should start looking into fishing net as an alternative? Maybe start filling your cars with 87 octane while you’re at it…
There’s a difference between being ‘thrifty’ & being frugal.
Carry on
#70
You already got rammed when you bought the car.
Literally every alternative posted before the gutter trash.
Carry on
Carry on
#71
The cost of the protection mechanism was not the driver behind my Gutter Guard protectors. Instead quickly getting something installed to protect the delicate radiator and condenser was the motivator. On a previous Porsche road debris damaged my condenser and its replacement plus freon was expensive.
I could not find anything available commercially to protect the grills on a 992 with dynamic louvers (no sport design bumper), hence the mesh cylinders, which just happened to be inexpensive.
Jason
Jason
The following 10 users liked this post by BOPE:
asunnyhero (03-21-2023),
IPA1 (12-17-2022),
KLOC (03-22-2023),
#72
Jason
Jason
PaperFlea (03-18-2023)
#73
Jason
Jason
Much of the black paint has come off of my grilles...secondary benefit of plastic is that the uniform color will probably be maintained longer.
#74
Hey, I like your SeaSucker bike rack; I have one too and love it!
Jason
#75
Worried about the SeaSucker next week. Doing about 500mile round trip, but this time, with a significantly heavy chain/lock combination (6ft Abus 8Ks). I hope it holds the extra weight (~10lbs) "at speed".
