The Porsche 992 Aftermarket Wheel Thread
Old 07-12-2023, 12:18 AM
  #526
4 Rings
4 Rings's Avatar
Originally Posted by Boucherom
4rings: I love the wheels! Also really like the side decals...are they white or maybe silver? If you wouldn't mind sharing, where did you get them?
@Boucherom it’s Matt white but it was from a place called renndecal.
i looked and it doesn’t appear their site is up.
but go look I saw something on Etsy for around $50. It’s the heritage edition lower decal.
Boucherom (07-12-2023)
Old 07-12-2023, 04:35 PM
  #527
Eric Busto
Eric Busto's Avatar
Does anyone have the HRE R101LWs on a C2S using HRE's recommend fitment (20x9.00 ET45 & 21x11.50 ET58)? I'm concerned about the fronts being 1/2" wider than stock, as I don't much care for the stretched look. Is it noticeable? Pictures would be appreciated; I don't trust online renders.
Old 07-12-2023, 05:38 PM
  #528
BlitzedTT
BlitzedTT's Avatar
Originally Posted by SupremePower
This is 20 x 9 and 21 x 12 w 245/35/20 and 305/30/21
But what are the offsets of those wheels? All of the examples appear to be lowered, and likely have a lower offset than 45, so this is not really an accurate representation of the spec that the poster was asking about.
Old 07-12-2023, 07:49 PM
  #529
AlterZgo
AlterZgo's Avatar
Received 1,949 Likes on 791 Posts
I don't have HREs, but I'm running 21x9 +48 offset BBS FI-Rs with a 7mm spacer and 255-35-20 tires so this would be equal to a 21x9 +41 offset rim with slightly wider and taller tires than stock. The extra width of the 9" wide front rim will pose no issues w/ the HRE recommended fitment. In fact, on stock 245-35-20 tires, it would be a conservative set up if the car is lowered. If the car is stock height it will be fine. Personally, if I got that set up you have listed for the HREs, I'd still add 7mm spacers F and R. Here are some very detailed info and pictures of my set up if you are curious. Scroll down to the 3rd version of my car w/ the FI-Rs for measurements, picture, etc.
Eric Busto (07-12-2023)
Old 07-13-2023, 11:45 AM
  #530
tourenwagen
tourenwagen's Avatar
Received 4,332 Likes on 1,188 Posts
Not super noticeable. I've had both the Michelins and Pirelli's on my front 9" wide 300 Classics.
The wheels below are the same, just powder coated. In my opinion the Pirelli looks very slightly more stretched on a 9" than the Michelin.
As far as offset goes, I have the same as you quoted above, but I'm running an 18mm spacer up front and a 14mm spacer in the rear.
Michelins:
Pirellis:
The following 3 users liked this post by tourenwagen:
AlterZgo (07-13-2023), Charcharius (07-13-2023), Ed99 (01-13-2024)
Old 07-13-2023, 12:38 PM
  #531
T1M3LESS911
T1M3LESS911's Avatar
I believe those were the initial recommended offsets I got as well from HRE when I was about to order a set of P104SCs back in 2021.
I had a feeling they were a bit conservative since I was running 15mm f/r spacers on my OEM set.
Back then, I wasn’t as familiar with the 992s and considering it was my first set of aftermarket wheels, I didn’t go crazy.
The P104SCs that I had were 20x9 et 45, 21x12 et 60 on OEM tires.
This is how they looked on the car -
While these looked good on the car, I still felt that this was a bit conservative.
There was definitely some room to fit a more aggressive setup/offset.
Second set was HRE Classic 300s
21x9.5, 22x12.5
The Classics were very close in terms the fitment that I personally wanted.. i just felt that the fronts poked a little bit more than the rears…
So in my third set of HREs I went with 21x9.5 (same as the classic 300s) but went with slightly wider rear setup 22x13.. and this set up has no issues whatsoever….
If I ever got a 992 again.., I would do the same wheel set up…. AND these HRE 527S wheels are for sale by the way with tires and TPMS.
The following 9 users liked this post by T1M3LESS911:
alin2 (07-13-2023), AlterZgo (07-13-2023), Jeahbladejeah (07-13-2023), Master Deep (07-13-2023), mattchow (07-13-2023), minn19 (07-13-2023), pkalhan (07-13-2023), tourenwagen (07-13-2023), ZacapaXO (08-13-2023) and 4 others liked this post. (Show less...)
Old 07-13-2023, 12:42 PM
  #532
tourenwagen
^ every one of your setups have been stellar @T1M3LESS911 but these 527's are just next level!
Old 07-13-2023, 12:55 PM
  #533
T1M3LESS911
Appreciate that man! Let me know if you’re ready to switch out of the Classic 300s lol.
I’ll deliver the 527s to you
Old 07-13-2023, 01:11 PM
  #534
tourenwagen
Trust me. The thought has crossed my mind
Old 07-13-2023, 04:12 PM
  #535
Shogunade
Shogunade's Avatar
Received 1,899 Likes on 1,070 Posts
If I didn't have centerlocks I'd just follow @T1M3LESS911 around and pick up his used wheels.
The following 4 users liked this post by Shogunade:
alin2 (07-13-2023), AlterZgo (07-13-2023), Jeahbladejeah (07-14-2023), pkalhan (07-13-2023)
Old 07-13-2023, 05:51 PM
  #536
T1M3LESS911
LOL.. not a bad idea.
Did you end up ordering a set of wheels for yourself as well?
Old 07-13-2023, 06:41 PM
  #537
WheelsB
Basic Sponsor
WheelsB's Avatar
Here is the latest 992 we've completed: a 992 Turbo S coupe with body kit from 9 Design (aka 1016 Industries). Carbon Fiber Hood, Front Spoiler, Side Skirts, Side Air Intake, Rear Diffuser, & Wing.
Wheels are custom built 2-piece ANRKY performance wheels: RS5.2's with color matched finish.
Wheels Boutique // 786 249 0127 // Sales@wheelsboutique.com
Follow us on YouTube: www.youtube.com/user/WheelsBoutique
Largest Dealer In The World for HRE Wheels, ANRKY Wheels, Vorsteiner Wheels & Aero, Akrapovic Exhaust, & iPE Exhaust
BBS, Forgeline, & TechArt Premium Dealer
Brembo / Rotiform / KW / H&R / Novitec / Brabus / Mansory and tons more...
Old 07-13-2023, 07:03 PM
  #538
Shogunade
Shogunade's Avatar
Yes. Expecting them any day now.
T1M3LESS911 (07-13-2023)
Old 07-13-2023, 08:44 PM
  #539
Master Deep
Master Deep's Avatar
Any Pros and Cons of Flat Lip vs Step Lip?
Old 07-13-2023, 09:48 PM
  #540
Shogunade
Shogunade's Avatar
Purely from an aesthetic standpoint I have to say the step lip is so much better.
Quick Reply: The Porsche 992 Aftermarket Wheel Thread
