Looking at a set of centerlock wheels but not sure if they'll fit on my 992 GTS RWD...
Rear 12.5 ET 48
Front 9.5 ET45
Does anyone know for certain that they will fit or not? Appreciate the help!
Fronts will be fine but rears will stick out quite aggressively, especially if your car is not lowered. My rear rims and tires are 21x11.5 ET 50 with 315-30-21 tires. See picture below. Your 21x12.5 ET 48 will stick out an additional 1/2" so it's pretty aggressive. If you run 305 tires, it probably won't rub but tire will look very stretched. If you run 315 tires, you may need to add addt'l camber.
Rear camber is currently -2.75. I'm really only worried about rubbing not appearance as these will be primarily track use. I'll keep stock rims as a back up.
With -2.75 degree of rear camber I think 21x12.5 +48 won’t rub unless you run a really square sidewall 315 or wider tire.
Awesome, BC Forged came out great, our #1 selling wheel for Porsches. A small drop would complete it!
-Josh
__________________ Your #1 Dealer for Aftermarket Performance Products
BC Forged / Soul Performance / Akrapovic / Bilstein / HRE / AL13 / CSF + more Orange County, CA Email: info@merakiautoworks.com Text/Call: 213 394 2886 Website:www.MerakiAutoworks.com
