Spoiler Error Message
Spoiler Error message appeared again - originally appeared @ 500+ miles - a vehicle restart seemingly cleared it that time - now, just over 2000 miles and it appeared again - vehicle restart did not clear it this time, and a new message appeared saying "Spoiler Failure" - trying to extend and retract manually from the main screen only got me another message saying the Rear Spoiler was "stuck midway" (i forget the actual words) -- is there any way to manually crank it up or down ? i doubt there is, but never hurts to ask
This was a common problem on the 991 generation TT/TTS.
Dealer visit required methinks if history is any guidance.
Update:
Dealer visit determined spoiler disassembly required to find malfunction and order part(s) as needed - i was advised to expect longer than usual delay for part(s) to arrive -- appt set for 2 weeks from today
Footnote:
Service manager also asked me if the Black portion of the spoiler (Sport design pkg in gloss black) was something i had taken off and had painted, then reinstalled - seemed like a quirky question to me, since the she had just said minutes before, that she has been working there 11yrs and has seen her share of spoiler problems
(subliminal passive redirection of the issue being my fault?) -- sure felt that way, but i digress
Footnote:
![ooops](https://rennlist.com/forums/graemlins/icon501.gif)
Update:
Footnote:
(subliminal passive redirection of the issue being my fault?) -- sure felt that way, but i digress![ooops](https://rennlist.com/forums/graemlins/icon501.gif)
Footnote:
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
RD16RR (03-11-2021)
Hope it gets fixed quickly - sure doesn't sound like it though. Agree - there is nothing that bothers me more for when a "seasoned veteran" of the service dept. doesn't know the product or insinuates my involvement with it - like without it, the car would always be perfect. ![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
Always Auto, via the mode dial...I used the button on the main screen to retract the front spoiler 1 time, when it stayed fully deployed, and it worked - getting the errors: I would turn the dial to Sport - it then raises the spoiler (I believe at 70/75mph) automatically — Sport Plus would cause Front & Rear spoilers to deploy — it worked normally for approximately 1800 miles...the first Spoiler error message appeared at 500miles....White colored message on the display just to the right of the tach “Spoiler Error adapted driving permitted" — it cleared itself when I restarted the car — showed up again, with a turn of the dial to Sport again, then I went to Sport Plus and the message went to full Red color and said “Spoiler Failure - Reduce Speed" - sad to report, restarting the car has no effect on clearing it — (I actually forget if in Normal Mode if the rear raises at 70/75mph - I think it does/is supposed to)
Always Auto, via the mode dial...I used the button on the main screen to retract the front spoiler 1 time, when it stayed fully deployed, and it worked - getting the errors: I would turn the dial to Sport - it then raises the spoiler (I believe at 70/75mph) automatically — Sport Plus would cause Front & Rear spoilers to deploy — it worked normally for approximately 1800 miles...which is when the first Spoiler error message appeared....White colored message on the display just to the right of the tach “Spoiler Error adapted driving permitted" — it cleared itself when I restarted the car — showed up again, with a turn of the dial to Sport again, then I went to Sport Plus and the message went to full Red color and said “Spoiler Failure - Reduce Speed" - sad to report, restarting the car has no effect on clearing it — (I actually forget if in Normal Mode if the rear raises at 70/75mph - I think it does/is supposed to)
Update:
Footnote:
Footnote:
I can find out to see what was done if you would like to compare,
lol please tell me a car brand that doesn’t have problems. This is minor stuff reported by a few. I understand we don’t like it, but it’s life. I’ve owed almost every brand. They all have had issues.
The following 2 users liked this post by Td33:
JuanilloTurboS (03-14-2021),
RD16RR (03-16-2021)
yes, of course whatever you can share or find out would be appreciated
Update:
Spoiler error linked to Spoiler Control Unit - part ordered - told by service dept. they expect a 10 business day delay if part is not back ordered
If it is 10 business days, that translates to 2 weekends without it....remains to be seen
In the meantime, rear passenger window did not close completely, while actuating convertible top to close, as it should - happened twice - luckily service dept was able to duplicate it, so they can try to determine the cause/fix (hopefully)
Next note: pdk missed engaging 2nd gear (also two times) when leaving stop light from 1st gear - being usually smooth on the throttle from stops, I was certain I was paddling up to 2nd gear with no response as I watched the revs slowly ramp up towards 6000 - after 3 or 4 paddle hits and backing off throttle, 2nd gear engaged as did all other gears after that - happened 2 times, same scenario - reported to service dept
