S/T Suspension Programming - GT3 update??
#196
Quick update - spent a few hours with Mars working on the various instrument panel displays options - here is the take aways:
Next up is full RS emulation - I have the steering wheel controls, and an updated chassis ECU ordered - we shall see if we can program the GT3 to have all the adjustability of the RS. Not sure if that will be better than the S/T suspension, but will be an interesting experiment and fun to play with all the settings.
Here is the S/T screen flash -
In S/T screen, you can see there is a clock at the bottom of the right display - this is normally where the mode is displayed (IE normal, sport, track)
this is the RS track display - notice 3 lines of date on the right display, ie water temp, oil temp, and oil pressure. Also note the Aero: Error display under tire pressure.
driving w/ the RS display - this is my current fav.
RS screen flash
tire pressures and temps in RS track display.
- Standard GT3 (wing / touring) Display - sport chrono mode pop ups and mode display in normal display (bottom of right display). No tire temp display. Track display has two lines of data on right display. Number on dials in white.
- S/T display - no sport chrono mode pop up, and no mode display in normal display. You can manually select the mode display in the right instrument and it works. Also, the mode selector still selects modes and displays in PCM. Numbers on dials in cool green - nice. Tire pressure and temp display - other than tire temps, track display same. One interesting learning - if you set the transmission to manual in S/T display, there is no gear display, other the R in reverse, but the shift ladders are always visable. However, there is no other indication of current gear in PDK, so not really a good option.
- RS display. Sport Chrono pop-ups and better track display. This is my preferred display currently. The only issue is that in track display, under tire pressure, you have an Aero:Error message, as there obviously is no aero. I'm trying to figure out how to block this message, but no luck so far. Its not a system fault, just a white display message as you can see in attached photos. . .Numbers in white.
RS screen flash
#197
Just got the S/T suspension coded and went for a ride! It is truly remarkable how much more compliant the car is over broken tarmac. The roads near my house are very low speed (25mph) and bad. Previously very jarring to drive through and now it is so much better.
Track on dampers still feel more compliant at low speed than sports without the flash. I have a track day next weekend and will report back how it feels. Unfortunately won’t be very empirical with lap times since I am also changing camber and different tires this week. Regardless so happy with this! It should be on everyone’s todo list
The following 5 users liked this post by dadgar:
aarodynamics (08-04-2024),
catdog2 (08-04-2024),
cyn (08-05-2024),
dixonk (08-04-2024),
EMdoc (08-04-2024)
#198
Also chiming in after the ST code today at dadgar's (thank you for the hospitality). This is one of those changes that is immediately noticeable and makes the car much more livable, especially for those of us who do not track.
Used to have to get to 45mph+ for the dampening to kick in. Now it's there right off the line. Still the stiff ride that we all want with just a little bit of buttery smoothness on top instead of the unnecessary jarring/harshness that used to be present.
On a scale of 1-10 (10 being max harshness), I'd say it's dropped from a 9 to a 7.5. Not too hard, not too soft, just right. Like a more aggressive version of the x73 suspension on my 981. Exactly what I was looking for.
Kudos to all involved for figuring this out.
The following 6 users liked this post by seatactony:
cyn (08-05-2024),
JCBH (08-04-2024),
and 1 others liked this post.
#199
This is why RL exists: car enthusiasts sharing ideas. This is a phenomenal piece of work.
That said, Porsche software is proprietary and subject to copyright laws. Whether Porsche opts to make an issue with this remains to be seen.
usctrojanGT3 (08-05-2024)
#202
#203
#204
Went for a long drive today around Jackson Hole - I continue to be amazed with the difference the S/T dampening makes in drivability - I also really like the RS Track Display. One thing that I wasn't aware of - if you push the button in the middle of the mode dial, you get a menu where you can select options for each mode (IE Sport and Track) - for me, I always want Track Display, Normal PASM (soft), and exhaust valves open - now when I change modes, the display stays in track mode and the suspension stays in normal . . . love it. I can then select PASM sport from the dash switch if needed, and I have the diamond button on the steering wheel programed for exhaust valves so can quite her down if needed. I really like the RS track display as well with the tire temps - very cool. I'm hoping we can figure out how to set the flash screen logo, but having it show GT3RS doesn't really bother me much . . .
On the Dakar question, I think the suspension controller is the same, but shock different - I see no reason we couldn't program the Dakar settings in PASM - it may or may not work with the GT3 shocks, but it's only software, so wouldn't hurt anything to try it out. Or, if you wanted to make a Dakar clone, that would be relatively easy to do. There is a Dakar instrument panel configuration, but haven't loaded that one to try it out.
There cars are fairly configurable and modular - once you install the correct hardware, you can most likely program to be any flavor you want.
cyn (08-05-2024)
#205
#206
#207
Yes - that's what gives us GT3, Touring, ST or RS displays - but it seems that you cannot choose one display "skin" and then have a different splash logo - IE have all the S/T green displays, but have it display touring at start up . . . for me, I prefer the RS display, and can live with the RS logo popup on start up and shut down . . .
#208
#209
The following 3 users liked this post by seatactony:
#210
I spent a few hour with Mars again tonight trying to figure this out and no luck so far . . . yeah, the S/T display doesn't work for me as it doesn't display modes (normal, sport, track) . . . but the RS display does display modes like the standard GT3, and it has a nicer track display, which is my normal screen. It shows Oil temp, pressure, and water temp on the right display whereas the GT3 track display only shows oil pressure and water temp. The RS display also shows tire temps, which is very useful. Hopefully as some point we will figure out how to mix and match display symbology, but so far no luck.
Normal GT3 / T Track Display - water temp and oil pressure on the RH display, and tire pressure, but no tire temp on the LH dispaly
GT3Rs display - water temp, oil temp, and oil pressure on the RH side, and tire pressure and tire temp on the LH side.
The following 5 users liked this post by f4bones:
718socal (08-05-2024),
catdog2 (08-05-2024),
Diablo Dude (08-05-2024),
dixonk (08-05-2024),
rnlst_log (08-05-2024)
