Second Service?
#46
Regarding the brake fluid exchange : make sure you trust your service department : most brake fluid exchanges at the dealer go like this : use a turkey baster to suck the reservoir dry,then fill it up. Done. There's your 250$. Also,if they are actually bleeding each caliper like they're supposed to,make sure they clean the caliper really well with water. Otherwise the paint from the calipers will vanish. Ask me how I know. I didn't do it,the dealer did...
The following 5 users liked this post by neanicu:
4carl (10-24-2023),
Diablo Dude (12-30-2023),
GrantG (10-24-2023),
shrimp money (10-24-2023),
subshooter (10-24-2023)
#47
My Porsche dealer is quoting me $2,200 for my 2 year service on my 992 GT3, inclusive of plugs, air filters, and brake flush. I'm inclined to just go ahead and do it, despite the need-questionability of replacing the plugs @ only 2,500mi, in order to maintain the service records.
REPLACE Engine Oil and Filter
• CHECK / Reset Maintenance Interval
• PERFORM Multi-Point Inspection: Fluid Levels, Belts, Brake Pads, Wipers, Tires, Interior
• INSPECT Air Filter Element
• REPLACE Pollen Pre-Filter Element (in Conjunction w/ Particle Filter)
• REPLACE Particle Filter
Additional
• PERFORM Brake Fluid Exchange Service (Every 2 Years, Regardless of Mileage)
• REPLACE Spark Plugs
Additional
GrantG (10-24-2023)
#48
#50
I did my 2 year service today, I had some great help, Subshooter sent me a few Videos which was a lot of help, and he answered my questions I had.. Thanks again Mark!!
My dealer wanted $3700 for two year maintenance service. Also anybody thats going to do the maintenance service themselves first make sure you have a 14 mm 12 point deep socket thin wall. That is the only socket that will go through the passageway where you remove the coil from to get to the plugs. I picked up one today at NAPA with tax was under seven bucks. Its actually a spark plug socket.
The following 2 users liked this post by Art gt3rs:
GrantG (12-30-2023),
subshooter (12-31-2023)
#51
As I've recommended before,get this one. If you don't like a true American,blue collar worker supporter company like Lisle tools,get it under different names : chances are,it's just rebranded but still made by Lisle.
Why you should get this one besides the reasons stated above? Because of the integrated swivel head which will help you in tight spaces and will prevent you from ever loading the spark plug sideways,whether tightening or loosening,thus decreasing the chance of breaking the porcelain.
Lisle 63080 14MM Swivel 12 PT. Spark Plug Socket https://a.co/d/4DKAsj5
The following 2 users liked this post by neanicu:
BlazinPond (12-31-2023),
dixonk (01-01-2024)
#53
neanicu (12-30-2023)
#55
as far as a using a swivel headed socket, I dont think thats the optimal tool for this procedure. Just my opinion.🙂
#56
My dealer wanted $3700 for two year maintenance service. Also anybody that’s going to do the maintenance service themselves …first make sure you have a 14 mm 12 point deep socket thin wall. That is the only socket that will go through the passageway where you remove the coil from to get to the plugs. I picked up one today at NAPA with tax was under seven bucks. It’s actually a spark plug socket.
The following 2 users liked this post by subshooter:
Diablo Dude (12-31-2023),
GrantG (12-31-2023)
#57
The hardest part I'd say was a) having the optionality of 3/8 extensions, and b) figuring out the right sequence of extensions to get the furthest plug in. I presume this job was more difficult on the 991 with the mufflers in the way?
Good tip from grant on the Hazet socket. Only german tools allowed.
also, these are pretty awesome. https://www.hazet.de/en/products/new...tion-light-set
The following 2 users liked this post by ShakeNBake:
Diablo Dude (05-23-2024),
GrantG (12-31-2023)
#58
my car have 5K miles
i need to go to the dealer for a recall and 2 years service
cost $3795Oil change
Air Filter
Cabin Filter
Brake Flush
Lubricate Chassis
Re-torque Driveshafts
Replace Spark plugs
if i take the car to local Porsche repair shop (not to Porsche dealership)
will cost probably half
i will lose the warranty?
thanks
Air Filter
Cabin Filter
Brake Flush
Lubricate Chassis
Replace Spark plugs
thanks
