Bluetooth is driving me crazy
Old 12-12-2016, 10:24 AM
pprj
pprj's Avatar
Default Bluetooth is driving me crazy
Hi there guys,
A thousand miles later, I'm loving my 2C. Easy to live with on a daily basis, the seat is extremely comfortable, the engine noise.... you guys know all that. No need to repeat it.
But the bluetooth is driving me crazy.
On several occasions only the phone call part connected. The music streaming was off. I tried everything and nothing worked.
Then, the next morning, everything works well, only to fail again 2 days later.
I can't find a pattern. I have no idea what is causing this.
Do I need to have the PCM software updated? Any suggestion would be extremely appreciated.
Thank you.
Old 12-12-2016, 10:51 AM
996_soon
996_soon's Avatar
Interesting you mention this as I also at times have to manually turn on the "Media audio" from my phone. The "Call audio" always connects. What type of phone do you have? I just think its my Samsung S5.
Im curious to see if iPhone users experience the same.
BTW - I have a 15 C2.
Old 12-12-2016, 12:08 PM
n2cars
n2cars's Avatar
iPhone 6 and 2016 C2 .. NO.. issues
Old 12-12-2016, 12:56 PM
arch7
arch7's Avatar
Same issues recently with my iPhone 7 and '17 C2. Haven't tried anything yet to fix it, but you are not alone!
Old 12-12-2016, 01:02 PM
Maxr
Maxr's Avatar
Very annoying glitch that I've learned to deal with as well. If you press and hold the sound and info buttons for several seconds, the PCM will restart and you can go back into your phone Bluetooth settings and connect to the PCM. This will reset it and work for several months. You'll have to do it again eventually.
Old 12-12-2016, 02:02 PM
pprj
pprj's Avatar
Samsung S7 here. Works on my Audi and Toyota perfectly. Zero issues. On the 2013 C2 is where I'm having issues. This has to be a software problem.
I wonder if Porsche has an update available.
Old 12-12-2016, 02:03 PM
Needsdecaf
Needsdecaf's Avatar
Received 2,603 Likes on 1,618 Posts
My Cayenne occasionally will do this as well. It will sit there as if it's on a call, blanking everything out, but nothing.
I usually end up removing the phone from the device list and re-pairing it to repair it (see what I did there?)
Old 12-13-2016, 02:23 AM
ipse dixit
ipse dixit's Avatar
Received 11,723 Likes on 5,121 Posts
Yes
Old 12-25-2016, 01:55 PM
pprj
pprj's Avatar
Guys, software was updated by dealer. I will report again in a few days. Let's hope it fixes the problem.
Old 12-26-2016, 07:03 PM
Cristophosphorus
Cristophosphorus's Avatar
I had the same issues on my 2013 C2S. BT Audio worked 50% of the time.
With my 2016 GTS, I've had 99% reliability. The only thing I've noticed is that my BT Audio does not automatically connect as of late (after adding a Huawei Watch and Bose BT headphones to my phone BT list). After disconnecting and reconnecting again, it seems to work just fine.
Old 12-28-2016, 02:29 AM
bright_medal
bright_medal's Avatar
I had a Huawei Watch and it unfortunately caused my car Bluetooth to go berserk. FYI, it was paired with an iPhone and my BMW BT system. Even though I really liked the watch, I had to get rid of it. No problems thereafter. Hope another users experience helps
Old 12-28-2016, 10:22 AM
bernpep
bernpep's Avatar
My 2013 was 50% as well. No one could figure it out. My 2016 is 99.9 % with iPhone
Old 12-28-2016, 07:51 PM
bmxtreme
bmxtreme's Avatar
Even when it works, it's a piece of s|-|it. It takes about a minute to initialize and by about 15sec, the RADIO auto switch back to FM, and you need to manually switch to AUX-BT. I gave up on BT audio and used a BT receiver plugged into the AUX jack.
Old 12-28-2016, 07:56 PM
bright_medal
Originally Posted by bmxtreme
Even when it works, it's a piece of s - it. It takes about a minute to initialize and by about 15sec, the RADIO auto switch back to FM, and you need to manually switch to AUX-BT. I gave up on BT audio and used a BT receiver plugged into the AUX jack.
I have the same frustration regarding the delay. Which BT receiver are you using? How do you deal with phone calls? Do you pair it with both the car for phone and the aux BT for music? Thanks.
Old 12-28-2016, 10:18 PM
Homeles
Homeles's Avatar
iPhone 6, escort radar detector, ALP jammers all connected BT without problems
Quick Reply: Bluetooth is driving me crazy
