What is the current state of the 'engine stumble' issue?
Old 12-11-2015, 10:45 PM
  #136
stealthboy
stealthboy's Avatar
Originally Posted by 96redLT4
I am curious stealthboy how you broke your car in. Did you follow P recommendations? Also at what point did you first change the engine oil?
Jim
I followed Porsche recommendations. I did my first oil change at 5000 miles.
Old 12-12-2015, 12:40 AM
  #137
duxsi
duxsi's Avatar
Originally Posted by squid42
Is your car manual or PDK? Which model do you have?
C2S Manual.
Followed the engine break-in guidelines and changed oil at 5k.
Old 12-13-2015, 01:22 AM
  #138
96redLT4
96redLT4's Avatar
I was just driving my 16 GTS today and really paying attention to the RPMs. I can't help but think it has something to do with 'hanging out' in the lower RPM range. It 'feels' like the motor is built to live in the 3500 to 5K range. Everyone knows that you're not supposed to lug these engines but I wonder if the stumble, which seems to always occur below 3K RPM, has something to do w the ECU dealing with lower revs. Does this make sense?
J
Old 12-13-2015, 06:15 AM
  #139
one-rennlist
one-rennlist's Avatar
J
With my car it's more apparent when depressing the accelerator lightly after overrun. I also observed it happening more often when using low revs and low power demand.
Old 12-13-2015, 07:56 AM
  #140
MagicRat
MagicRat's Avatar
Is this an issue that affects only US cars, or have European ones had it too?
Old 12-13-2015, 10:52 AM
  #141
squid42
squid42's Avatar
Originally Posted by duxsi
It's definitely rpm related and not speed related.
At 75-80mph at around 2500-2600 rpm in 7th gear (on a very slight incline) I can replicate a prolonged and persistent stumble, which manifests itself in the form of a fishing line tug sensation, or a very mild but continuous misfire.
Unfortunately there is no way to record the sensation, nor is there any definitive change in engine noise.
It feels like fuel or air starvation.
When accelerating moderately in 2nd gear, it stumbles without fail between 2500-2600rpm.
For a c2s manual 2500-2600 rpm are translation to cruising with 90 km/h. In 5th gear 2500 rpm is 86.9 km/h and 2600 rpm is 90.4 km/h.
In Germany one of the most import efficiency statements is going in a straight line 90 km/h precisely. Fuel consumption at this specific speed is still a major sales influence. Although technically the governments moved on to slightly more useful measures it is still in use. And I think it was in much more use during the time that the direct injection engines for the post-M97 era were developed.
For me this specific bit pushes the whole affair more into a software corner where the car is tuned to perform well on specific artificial benchmarks.
Old 12-13-2015, 12:52 PM
  #142
duxsi
duxsi's Avatar
For me this specific bit pushes the whole affair more into a software corner where the car is turned to perform well on specific artificial benchmarks.
It is extremely noticeable in 7th gear, when sitting between 2500 and 2600 rpm under mild load. A constant tugging (like a child kicking the back of your seat on a plane..).
Old 12-13-2015, 04:02 PM
  #143
Larry Cable
Larry Cable's Avatar
Received 3,632 Likes on 2,358 Posts
J
if this was the case I'd suggest that more PDK cars would exhibit this as they
spend their life (courtesy PDK programming) keeping in that rpm band usually
in 7th gear!
Old 12-13-2015, 04:03 PM
  #144
Larry Cable
I think that Daily Mail report suggested it was European models also
Old 12-13-2015, 04:25 PM
  #145
larspronne
larspronne's Avatar
yes my EU 2S 20,000miles had it and it got progressive worse untill I got the engine fault messages and it stumbled like crazy and had an awful rough idle.
Look at my specific thread on the topic.
turned out to be a faulty "magnetic valve lifter" which they fixed on warranty, and now its buttery smooth throughout the rev range in any mode, warm/cold, part/full throttle.
So no more stumble after the replaced valve lifter for me!
Old 12-13-2015, 04:31 PM
  #146
duxsi
duxsi's Avatar
Unfortunately it also affects some owners in Europe, the Middle East and one in the Far East.
I have attached the results of a survey taken about a year ago.
Stumble Survey Results.xls
Old 12-14-2015, 04:58 AM
  #147
MagicRat
MagicRat's Avatar
Good point. I guess I'm just disinclined to believe anything I read in the Mail! Kind of our answer to Fox News, though maybe they can be trusted about cars...
Old 12-14-2015, 01:38 PM
  #148
duxsi
duxsi's Avatar
Larspronne,
Can you please elaborate after how many miles your stumble started?
Is it at the same rpm spot every time.
Most of us do not have a rough idle, so I'm not sure if these are related.
Thanks in advance...
Old 12-14-2015, 01:45 PM
  #149
larspronne
larspronne's Avatar
Larspronne,
im not 100% sure as I picked it up with about 12,000 miles on it. I actually only realized it might be a problem after reading about it here.
the rough idle was only associated with the issue with the engine light described in this thread:https://rennlist.com/forums/991/8986...idle-help.html
after the fixed the valve lifter that caused the rough idle/misfire, the stumble was also completely gone.
Old 12-14-2015, 07:38 PM
  #150
duxsi
duxsi's Avatar
Thank you for the clarification.
I didn't realize that a valve lifter could be kinda bad with no error codes until an almost complete failure.
I was under the impression that it's pretty binary in its operation.
Quick Reply: What is the current state of the 'engine stumble' issue?
