What is the current state of the 'engine stumble' issue?
#211
In regards to the O2 sensor swap, in a few cases, including mine, there has been a marked improvement. My car isn't completely cured, but I'd have to say it's undoubtedly 80% better. The stumble has turned out to be a very complex problem, as no single fix seems to have cured it completely.
Once again, hats off to PCNA for all of their hard work in resolving this.
#214
Mine was fixed then came back now it seems to be mostly gone again after the 40k service but I have a parked gas smell....rather the stumble frankly
I think they have software updates that are a patch but not a solution
#216
Anyhoo, thanks for letting me know. I have made an appointment with my dealer for this afternoon to have them inspect the exhaust for debris and inquire why I wasn't informed of this potential issue when purchasing the car.
I suspect this will cost me a small fortune but for peace of mind...
Thanks again, this forum is truly a godsend.
#217
Originally Posted by tse
This really pisses me off, we Canadians are always getting screwed.
The Canadian part was a joke ... no need for an appointment
Only affects yellow cars.
#218
#219
I don't think this is a carbon build up issue on the intake valves. I've had the stumble since day zero. Although I have a 981, it is the same 9A1 engine in the 991.1 Base model and the 991.1 S model which all share a similar symptom. Whatever the problem is, it is common to those platforms. (i.e. 3.4 and 3.8 L engines.)
#222
I plan to install the Softronic software this week. I’ll let you know my experience, weather permitting. I’m told we have another NorEaster headed our way.
#224
I installed the Softronic software in my 996 turbo and had many trouble free years of road and track fun, with a significant improvement in torque and power.
If the dealer and Porsche don’t have a solution, why not try a different software map? It’s easy enough to reset to the factory settings.
