engine overheat
Seems like SS was somehow inhibiting cooling based on what he said. I always disable it except long road trips to get the sailing function. Even then it's muscle memory that it gets turned back off approaching an off ramp.
The gas it saves is so minuscule anyway and in most cases it puts the engine through another start cycle when even Al Gore would say it wasn't worth it. In those occasions you know you'll be sitting for a while in between moving, you can always re-enable it then.
One or two red lights on the left to have fun. One red light on the right always.![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
The EPA gas mileage drive cycle has some idle time as well.
Here is a link that shows the amount of idle time:
http://www.fueleconomy.gov/feg/fe_test_schedules.shtml
Thanks Eduardo! I'll keep everyone posted about the findings in case others have similar issues down the road. Hopefully a simple find and fix.
Spoke with my dealer, turns out fault codes for front radiator fan on both sides were triggered. After removing fender covers, both fans were jammed with gravel and dirt preventing then from spinning. No damage to the fans or radiator was discovered after cleaning out the blockage. However, this was not covered by warranty, considered wear and tear! Bad design imo due to lack of mesh covers in the front wheel wells where the fans are ventilated but exposed. You can turn your front wheels all the way to the right and see the left radiator fan exposed.
I'll have to consider some aftermarket mesh fix for this. Wonder if the 997's had this problem?
Received 5,410 Likes
OM40, does your car see track duty? Glad it's fixed. Couple guys here have done great work with the mesh screens.
Sent from my iPhone using Rennlist
No track days as of yet. It is a dd in the Seattle rain but with under 7k miles. I've seen some good mesh threads for the front radiator apertures, but not for the fan openings in the wheel well. Perhaps someone will provide more details as to how they did those....
Yes they are louvered on the 991-cs as well, but the slats are wide and not meshed. Since both sides were involved, I can't chalk this up to bad luck with stray gravel. Seems like I need to clean out yearly to avoid this again in the future.
Thank you for bringing this up to our attention and great timing. FBC and inner fender coves are off and new plan to install some mesh also on the inner w/w liners similar to what the GT3 guys have been doing. T
Saludos,
Eduardo
Carmel
Can you please take some detailed pics and explanation of your solution to the fender cover/mesh project. I had looked at mine when they were off, but never got to it. I thought I'd need a really thin and flexible mesh.
Please keep us posted on your project.
Thanks!
