Has anyone personally installed a PSE exhaust on a 991S?
#61
Basic Sponsor
Best,
SOUL PERFORMANCE PRODUCTS
Quality Exhaust Solutions, Fair Pricing, and Outstanding Service
John Gaydos- Owner, Performance Specialist
Cell - (484) 883-6197
johng@soulpp.com
Jon Wheel - Marketing Manager
jwheel@soulpp.com
![](https://rennlist.com/forums/signaturepics/sigpic191275_4.gif)
johng@soulpp.com
jwheel@soulpp.com
#62
enuine Porsche Parts
Porsche Parts
Manufacturer: Porsche
Part Number: 991-111-437-07
Part: Center Muffler
Replaces: 991-111-437-05, 991-111-437-06
https://www.genuinenewparts.com/oem-...SABEgLDHfD_BwE
#64
Here's my last year's PSE list for my 2014 C4S Cab. I installed this myself at home, then to dealer for a $215 switch programming.
Some notes:
1. I ended up didn't use the vacuum tube (900-918-005-40) since I used the existing tube and cut it as needed.
2. Bought 2 vacuum hoses, as listed (991-111492-00). I really only needed one. Didn't return the 2nd one and used it as a heat-shield sleeve for part of the clear vacuum tube where it touches a metal part.
3. Your VIN is needed for them to sell you the correct parts, and to send you the correct switch (cab, roof, etc).
Some notes:
#65
Some notes:
Some notes:
#66
SPR Thanks so much this is exactly what I needed ! Did you re-use your existing S tips ? Did you order from "guininenewparts.com" I have never bought anything from them, how was your experience ?
#67
sessionstu, Bud,
I bought these from Sunsetporscheparts in Oregon and used the instructions from them. It's pretty much self explanatory when you lay everything out and see where the vacuum lines supposed to go.
I did reused my S tips and the 2 muffler clamps.
#68
Thanks guys. Got a PSE centre muffler for £235. I'm going to get it fitted then order the right switch panel and my local Porsche specialist can sort out the programming as they have the right kit.
Should be able to do everything except the tailpipes for about £500. Not a bad bargain.
#69
I bought some parts from Paramount Parts Store a couple of weeks ago. Excellent service. Prices were good. Comparable with the others. They're in North Carolina, so no sales tax unless you live there.
#70
Thanks. Did you use the same parts as the parts list from SPRTENT?
#71
After all the reading here what I can gather is that the S model OEM Non-PSE Tips are a bit shorter that the S PSE TIPS. The guy at Suncoast is verifying. That being said, what are the most like OEM or best aftermarket TIPS that folks have used for PSE ? 1K for 4 metal holes is ludicrous but if in fact the non PSE tips are shorter then it makes since to get the right length.
#72
Does anyone have a copy of the installation instructions they could send me ?
#73
I'm curious about the one some are getting from sunsetporsche. If someone can send me that one that would be great. Want to see if it's the same as the Porsche one.
#74
PM Sent thanks Weespeed !!! If anyone else needs it let me know and I will pass it forward.
