Ongoing change over valve issues on 991
#152
Has anybody been to able get PCNA to cover this? I don't care if this is a $20 fix or a $5000 one. Just out of principle, Porsche should step up and take ownership of this problem given its prevalence.
Rant.
Rant.
#153
2014 Carrera S w/ 18,000 miles checking in with a Cooling System Failure message last weekend.
I was at an autocross when it happened and was monitoring temps. No fluctuation in the oil and coolant temps. Turned on the heat and got nothing but ambient temp air. I'm out of warranty but have the Fidelity Platinum warranty. Scheduled an appointment with Porsche for next week.
#155
How did you do with PCNA? I'm running into the same problem on my '14 Cayman S. I've replaced all 5 COVs, replaced the vacuum pump, and the check valve going to the brake booster. I'm hoping PCNA will come through, but want to find out about "success" factors in negotiating for them to pick up the expense.
#156
For posterity, my 2014 991.1S has about 18,000 miles on it. One of the nine changeover valves went bust. I'm out of CPO warranty but I have the Fidelity Platinum warranty.
Took my car to Porsche, and they work with Fidelity Directly. Porsche charged about $900 total in labor and part (I think the part was around $50 so it was bout $850 for labor). I only had to pay for my deductible for the warranty.
#157
I live in the bay area so not having heat (especially in the summer) doesn't bother me quite yet. So I haven't acted on it yet because it doesn't sound like a cheap fix. I know I'm going to have to do it sooner or later though.
I'm interested to see if anyone had success with PCNA also.
#158
They didn't say one way or the other whether they'd pay for it. They just told me that I'm out of warranty and that I should take it to a Porsche service center.
#160
Is there anything difficult about replacing the wiring harness? Has anyone detailed that specific part of the process? I know that with an early 2013 MY car that I probably have very old revision COV's and once one of them inevitably fail, I want to go to a newer part number for sure.
#161
- Lack of heat
- PSE stuck in either "off" or "on" - won't toggle with the button
- Coolant warning fault
#162
The actual vacuum lines can be tough to get off. If there's some play, just cut that part off. You can work it off on the ones that have some room around them, but the ones deeper in the engine or under the transaxle, that's the only really fiddly part of the procedure.
#163
The wiring harness change is very easy. There adapter just clips into both sides. I bundled up the extra wire length.
#164
Seems like all .1's from what I've personally encountered. The common things people seem to run into are:
- Lack of heat
#165
I have a 991.2 but early 2016 delivery. Just joined this club....Coolant warning failure.
"it looks like we need to replace a valve on the back of the engine for the heater, per the diagnosis. We have the part here but it does require the engine to be lowered out as it is impossible to replace with the engine in the car. " UGH!!!
