Thinkdiag Magic
Old 12-25-2023, 02:22 PM
  #46
P991GTS
P991GTS's Avatar
Originally Posted by bokh
This one https://mythinkcar.com/products/thin...46636614353199
Use promo code THINKCAR20 to get an extra 20% off.
Thank you! I just ordered the "All Software" one.
Old 12-25-2023, 02:33 PM
  #47
thesaintusa
thesaintusa's Avatar
Has anybody figured out if you can get the brake lights to flash with the pedal being pressed once?
Old 12-25-2023, 02:48 PM
  #48
thesaintusa
Ditto.
The 20% discount promo worked as well. Thanks.
Having it shipped to the in-laws in the USA, so won't get it for 6 weeks the next time we see each other.
Will report what it does for a 991.2.
Old 12-25-2023, 11:31 PM
  #49
Ken718B
Ken718B's Avatar
Windows going up/down when you keep pressing the key to lock/unlock (courtesy of boldish on this forum)
1. System Selection -> Front-End Electronics -> Code/brush Hiding -> Rule Coding -> Coding value -> Coding value_2 -> "Coding value--Comfort functions--Window comfort open" Set to true
2. System Selection -> Front-End Electronics -> Code/brush Hiding -> Rule Coding -> Coding value -> Coding value_2 -> "Coding value--Comfort functions--Window comfort close" Set to true
3. System Selection -> Front-End Electronics -> Code/brush Hiding -> Rule Coding -> Coding value -> Coding value_1 -> "Coding value--Comfort functions--Comfort functions via door lock" (At the very bottom) Set to true
4. System Selection -> Front-End Electronics -> Code/brush Hiding -> Rule Coding -> Coding value -> Coding value_1 -> "Coding value--Comfort functions--Comfort functions via remote control" (At the very bottom) Set to true
what does setting Comfort functions--Comfort functions via door lock" (At the very bottom) Set to true do? I have done this on my 718 without setting Comfort functions--Comfort functions via door lock" to true and it works fine. However I can’t figure out what Comfort functions--Comfort functions via door lock" does. Do you know?
Old 12-26-2023, 07:57 PM
  #50
lunker325
lunker325's Avatar
Will this effectively replace the Launch devices, specifically the Launch X431 pros mini I just bought on Black Friday?
AdamSanta85 (12-26-2023)
Old 12-27-2023, 12:37 AM
  #51
B Russ
B Russ's Avatar
I take it I want to get All software version??
This could be Hours of fun
Old 12-31-2023, 03:16 PM
  #52
wkearney99
wkearney99's Avatar
Got one, it's defective. Something inside must have a loose solder joint or something. Won't power up unless the housing is seriously pressed-upon. Tried in three different vehicles to the same effect. Not the pins in the connector itself, something inside. And it appears to be plastic-welded shut so it's not like I could open it and fix the problem. Other ODB dongles work fine, both straight into the port or using a short extension. It's not the sockets.
Now I have to jump through the hoops of getting it replaced.
Old 12-31-2023, 05:34 PM
  #53
B Russ
B Russ's Avatar
I'm excited to try it, is it from a china company? It appears to be
Old 01-01-2024, 02:18 PM
  #54
thegenius
thegenius's Avatar
Just ordered one with a cheap Galaxy Tab. Will give it a try this weekend.
Want to code the windows up/down with the key for my 991 as well as the roof up/down on my 997 cab.
P991GTS (01-01-2024)
Old 01-02-2024, 05:25 AM
  #55
LFB
LFB's Avatar
Very interested to try accessing the over rev report on 991.2 GT3, and also to see if the instrument cluster can be coded to have the track TPMS that some cars lost a few years ago (https://rennlist.com/forums/991-gt3-...uitn-mode.html).
Old 01-02-2024, 12:25 PM
  #56
c615586
c615586's Avatar
I would like to try recoding a few things on my 991.1.
There are a couple of different versions of the tool on Amazon with a pretty broad range of prices. Which is the best/most cost effective? Is the basic $119 version with an iPhone usable for a starter setup?
Thanks in advance.
Old 01-02-2024, 03:40 PM
  #57
desmotesta
desmotesta's Avatar
Received 2,034 Likes on 963 Posts
Thanks in advance.
dont know about their entire range but dont go for the IOS version, its very limited in capability
c615586 (01-03-2024)
Old 01-02-2024, 03:47 PM
  #58
boldish
boldish's Avatar
I am not 100% sure and included a caveat in my original post that I wasn't sure if both #3 and #4 were required (which was not copied over to this new thread).
If you can get it working without either #3 or #4, then let us know.
Old 01-02-2024, 07:16 PM
  #59
Frankfurt1470
Frankfurt1470's Avatar
OK - I am getting started on this.
First question: Does any one of the experts know if I can program the Start/Stop-annoyance to "default off" when starting the car, instead of "default on" as it is right now?
Thank you!
Old 01-02-2024, 07:17 PM
  #60
wkearney99
wkearney99's Avatar
Supposedly there's no setting to disable it entirely, but it can be configured to remember 'last setting' and to change the last setting default to being off. I think it's in the AC settings for Eco mode?
Quick Reply: Thinkdiag Magic
