Excessive rear tire wear
I am sure this has been discussed but I cannot find a thread. On my 2018 targa 4S rear tires worn to the cord on the very inside at 6000 miles. The rest of the tire shows nominal wear across the tread. Are there suspension changes that can help this. This car is not going to be tracked.
That’s definitely well below average. I get around 10-12K out of my rears. I would definitely get an alignment. You can ask for a more street friendly alignment if your driving stile is a bit more mellow. Can likely get 15K+ on the rears with that style of alignment.
Originally Posted by Al.Fresco;[url=tel:17862393
17862393[/url]]That’s definitely well below average. I get around 10-12K out of my rears. I would definitely get an alignment. You can ask for a more street friendly alignment if your driving stile is a bit more mellow. Can likely get 15K+ on the rears with that style of alignment.
I encountered the same issue with my '18 GTS. Took to the local dealer and bought rear tires (most Porsche dealers will match or beat Tire Rack prices) and got a four wheel alignment. Rears were way out of alignment. I hope milage on new rears improves.
Off the showroom floor with a mix of track and street driving, I saw ~12k out of rears with a 991.2 Carrera with PS4S and TechArt springs, with the extreme inside going to cords seemingly suddenly (real reason is it's hard to see that far under the rear bumper compounded by a fair bit of meat left on the rest of the tire).
After a fresh alignment, saw ~15k out of a pair of rear PS4S—this time entirely on the street. Difference is it looks like the fronts can go a while yet, just like some of my previous Porsches with staggered setups.
Our local dealership just opened a new building with all new equipment. (I feel so lucky to have this support.) Three days ago, I had the Targa aligned. I drive a few DE days and mostly coastal roads. Hardly any highway driving.
"Inside rear wear is from aggressive track and back road driving. Outside is freeway wear." So I was told by another driver. Not that I believe it, but I think there are many factors here. I had the alignment set to factory spec so I could see for myself what is happening and move forward from here.
In the big scheme of things, I would be upset if I only got 4-5K out of a set of tires on any other car. However, getting 100-smiles/mile certainly allows me to deal with this much easier. For a Targa, I am just amazed at how it handles on a technical track. I don't feel handicapped with the extra weight. I am sure on a track with speed stretches, I'd feel the penalty.
Now that the alignment is reset and aligned on a new rack (not there is anything wrong with a string!), I will be watching the tire wear more closely. Getting a quick alignment check just driving into the service bay is a great tool available to us. I'll let you know how I adjust the camber on my Targa in a few months.
![](https://cimg0.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/alignment_reading1_2021_141ece752370ee765bd8bf4cef13971f15c1a685.jpg)
Received 3,443 Likes
What tire pressures are you running?
Jerrygreene (12-28-2021)
Any inside rear tire slippage thanks to no LSD—which rarely annoys me—skims off the last of the inner tread pretty quickly. In my case, well worn rears that still seemed to have enough meat on them for one more fun run (500 miles) simply didn't. Not sure when, exactly, the RR started showing cords, but my guess is after unloading the inside rear one too many times (I can think of a handful of instances over those 500 miles in the wet). It isn't much of a problem, but it's perfect for cleaning off rubber prematurely. Still, at 12-15k per set of rears, I am not complaining. That's not much worse than I got out of 986 Boxster rears on a lighter car with much less power and better balance.
The factory alignment is biased toward handling so they will wear on the inside. This according to the service manager. Asked for a more neutral alignment. They nailed the wear issue by setting right at edge of the green zone. Excellent wear and handling for everyday driving.
Doing well with the new Spyder, hope you are as well! If I find the perfect Speedster I will be back, but I will keep the Spyder since it is fantastic. I was actually running higher pressures when I sold it, and so the same with the Spyder.
Was running 31/39 which is standard partially loaded and fully loaded comfort. Now with new tires I am 34/44 . It is Winter here in the Colorado mountains near Aspen so it will be a while to see what happens. The car is driven briskly but at nowhere near track speeds on some exquisite twisty roads similar to the roads in the Black Forest but much rougher. They are a wonderful grippy ,smooth and comfortable tire. If I had not just happened to see the cord showing there would have been a blow out soon. Scary stuff. I do not have any competent alignment shops nearby so will wait.
