Porsche DME and Transmission control reprogram "AMC0" (To address Stop Sale)
#151
I have a manual but apparently they can not sue Porsche for letting me crater the gas mileage by running at high RPMs. Maybe if the upshift meter were improperly calibrated that would be different. Only in the USA!
#152
When is payment supposed to be sent?
#153
Mine renewed yesterday so I have a whole year to consider this. No smog for me this year but a new smog cert will be due next year. If anyone else has to renew their smog cert in CA in 2022 please post if the software update is required. I’m sure this is a CARB requirement so I’m not optimistic it won’t be required with next years renewal.
CarreraFahrer (08-28-2022)
#154
CarreraFahrer (08-29-2022)
#156
My dealer did the same thing to mine and I was pissed but after thinking about it I VERY rarely ever drive in sport plus mode so it's really a moot point in my case. My car is still just as quick as it was before the update and still has burbles when on it hard in sport mode so don't sweat it. Drive it and enjoy it and don't let some armchair jockey mechanic try to tell you that you lost 20 HP and that you "nuttered" your car.
BGLeduc (09-27-2022)
#157
Porsche_nuts (09-27-2022)
#158
I use sport plus more after the update than I ever did. Much more usable on the street and back roads (which equals more fun).
The following 3 users liked this post by Porsche_nuts:
#159
"roll back" isn't possible once completed.....from what I'm told.
Chuck245 (10-08-2022)
The following 3 users liked this post by Wellardmac:
#162
The following 4 users liked this post by PorscheC2S:
#163
The following 2 users liked this post by Porsche_nuts:
Chuck245 (10-08-2022),
shammerman (09-29-2022)
#164
2016 Porsche 981 AMCO Recall - re-program DME/TCU unit
To all those that wondered - I'm in Calif and had this done by Rector Motor in Burlingame. I only did it to avoid issues with the Calif Smog Certification. I've got over 83K+ miles (daily drive) and no track time. I wish I didn't have to have it done. The engine sounds like a vacuum cleaner and the Sport Exhaust is muted when you let off the accelerator at speed - doesn't matter if it's in Sport, Sport+. When I bought the 981 back in Jun 2016 my son says it was loud going down the street - and that's with-in the speed limit. I liked that - that's why I paid for the option. Now it sounds like any other Camry. i really have to punch the throttle thru 5K to hear anything..
Aside from the sound there IS some performance lost - acceleration is not as quick and the down shifts is slower and not as sharp. On the bright side I suppose the rear tires will wear a little longer and maybe the PDK clutches will last longer too. After the re-programming the PCM was reset - lost all my settings - no biggee - just had to reset it.
#165
Hi Folks! Has anyone confirmed that a COBB tune for PDK and ECU overwrites this update (or any update) and all is “restored” for those who desire max “aggression”? My 991.1 GTS was in this past week for new shoes. I declined this AMC0 update. Dealer reiterated it wasn’t done even afterwards and I called just now to confirm again. But something is “off” now.
I drove around a lot more today (100+ mixed miles) since my return home from the dealer (which I was on a phone call so I was driving calm). I have the AWE switchpath and notice in normal mode it sounds different with PSE off. And with PSE off it would normally still start to open up around 3K and by 5K it would be close to the volume of PSE on. Now it stays muted as if opening is no longer tied to RPMs.
In sport mode (PSE on) I could at 4000-4500 have this amazing sustained hollow going. Closer to an F1 sound and then screaming from there. That hollow is gone and maybe I’m paranoid but feel as if the cracking on pedal lift is more muted.
Seems odd. Especially when they’re telling me nothing on ECU and TCU was done. I usually only drive in manual mode with sport on except cruising on the highway I’ll go auto and turn off PSE. I only use Sport+ on the track and still manual shifts. Could there have been a “relearn” after new tires that somehow effectives things?. - sorry. I’m going a bit off track now. So puzzled though on why.
