Zunnsport 991.2 Outter Grill Set
dsddcd (05-12-2020)
Quite a lot of members have it. I just bought it from eBay (seller was Zunsport) with slight discount from eBay promotion.
I was thinking it's kinda pricy for what they're but after inspecting the design and quality, it's sees really worth it. nice strong clip design to attach to the bumper instead of cheap zip tie solutions on other less expensive options.
If you search Zunsport, you will find enough posts with pictures.
DavesPorsche (05-01-2020)
I know a lot of members use these on their 991.1s, however there was no solution for the 991.2 non sport design cars, unless you wanted to remove the bumper.
Anyone know if they have these outer grills for the 991.1 with parking sensors?
I've been toying the idea of grills. But all the solutions that dont require the bumper to be removed simply look cheap to me. I dont know if this is something I am in the minority in but I think the best way to do it is with the bumper off and it looks clean and flush. I am still hung up on if I want to remove the slats (leaning towards it) or just add the grills.
COOKINN (04-30-2020)
I am surprised to see this centre photo, as when I look at mine it appears the centre flaps stick out a lot and I thought there would be no way for this to work properly. Do the centre flaps touch up against the screen? Are they fairly tightly clipped in?
I found the outer grills using the link provide by the OP, but wasn't able to find the center.
Just found it as a complete set on Ebay.
https://www.ebay.com/itm/Porsche-Car...QAAOSw6O9eYihA
https://www.zunsport.com/en/porsche-...earch=zpr82016
This should be a link to the side and center grills as a kit
Have you had any issues with the side grilles and the moveable vanes?
Does it seem like enough clearance to avoid rubbing the vanes?
Originally Posted by F355bob
This on my 991.2 Carrera
