Zunnsport 991.2 Outter Grill Set
#76
The website works for me and lets me add to cart for both with and without parking sensors for full set or outer grill set only and for both finishes.
With parking sensors:
https://www.zunsport.com/en/porsche-...set?filter=328
Without parking sensors:
https://www.zunsport.com/en/porsche-...ors?filter=328
It could your web browser. May need to clear the cache.
T3X4S (05-08-2020)
#77
My gut feeling is these will look even better with the strakes removed. For those who have installed them, does that seem easy or feasible?
Funny thing is I hated the strakes on the Oak Green Carrera, but mind them a lot less and even sort of like them on the Brewster Green car. Paint color can be a funny thing…
Plus, in order to safely remove the strakes, you need to remove the front clip, which negates the whole reason for going with Zunsport in the first place.
YMMV,
DaveGee
#79
I think the overall fit and finish of these grills would bother me too much. Simply looks cheap. I dont know if this is from being pushed too much in the outer edges but they appear to be bulging out some too. Its great that you dont have to take out the bumper or a a temp solution if you damage one but not permanent.
In response to DaveGee’s previous post.
I just installed mine. Will try and take better photos another time when the car is outside. Very happy with the outer grilles. Not so much with the center. The gap on the top left is greater than top right on the center. Yours appears to be the same. I tried putting pressure on it, using a screwdriver to force the grille up a little to reduce the gap size etc.. I will work on it later when I have time but somewhat disappointed. Feel like the center grille needs a screw top center. Easy install!
#80
Installed the Zunpsport grills on my Targa 4S today. As others have stated, it was about a 15 minute job and did not require removing the front clip. The fitment of the outer grills is very good, and fitment of the center grill is just good. It could be better along the top edge. I may play with it later if it bugs me enough, but I’m likely the only person to notice it. And now all of you of course.
DaveGee
DaveGee
This was the post I was responding to, sorry.....
#81
I think I know what the problem is. Zoom in on the red circles in the attached pic. Those little nubs are part of the black center insert. I’m thinking if we just trim those back a bit the center grill will sit more flush. You go first.
DaveGee
DaveGee
#82
I ended up pulling my bumper and did it the hard way. Well worth the extra work.
F355bob (05-11-2020)
#84
#85
You live in CA. You go first. You guys are trendsetters! Let me know how it works out.
#86
Originally Posted by 911.
Correct. This the same black wire mesh, cut and basically sandwiched between the plastic trim that hold the motorized vanes. The center vent is OEM GT3/RS trim for 3rd radiator so its 100% bolt in.
