Zunnsport 991.2 Outter Grill Set
#106
Ordered the three piece set.
I was looking to add the center radiator for aesthetics and cooling reserves, but wondering how the middle rad replacement center piece and the center grille would play.
May still order the center radiator, will wait until the grills are fitted.
#107
It’s not clear from the Zunsport site, but the center grill actually screws into the black plastic filler plate to secure it (not very well btw). So, if you eventually plan to add the center radiator and remove the black filler plate, you’ll need to find another way to secure the Zunsport grill. Or buy a grill from another manufacturer that installs from the back side since you’ll have to take the front clip off anyway.
DaveGee
DaveGee
#108
If the center grill doesn't attach well with the provided hardware, I will remove the front bumper cover (which the Porsche manual identifies as "the front apron"?), and use better hardware to secure the center grill.
SeeForce (05-18-2020)
#114
Ordered and received the 3 piece grille set for my 991.2. Quick delivery and properly packaged.
On installation, one of the outer grills was found to have a pronounced kink on the outer ring.
In order to make it fit, the grill had to be manipulated to lessen the defect. Not happy to have dealt with this.
I informed Zunsport of the issue but was not really satisfied with their response. Buying from overseas can be an issue. Live and learn.
Probably should have returned the lot.
#115
I just ordered a full set and Peter from Zunsport provided the following promo discount code. I did tell him I'd post to this information to this forum for others to use.
Promotion Code RL112015 to receive your 20% Discount.
#116
DaveGee
