Time to bring out the battery tender.
Old 04-05-2020, 12:56 PM
  #61
JW911
JW911's Avatar
Yes, that 12v port in the center console is only live for about 5 minutes after you open the car door. Then it shuts off. I use a 12v air pump to add air to my tires and plug it in to that center console port. It typically shuts off about halfway through the 3rd tire. That's how I found out about this.
Old 04-05-2020, 01:34 PM
  #62
CSK 911 C4S
CSK 911 C4S's Avatar
If you have multiple idle vehicles this one is great. I keep at least one car, scooter and lawn tractor plugged in most of the time. I have mine placed on top of a cabinet in the center of the garage and 25' extension cables leading to the areas needed. Works great.
B Russ (04-09-2020)
Old 04-05-2020, 02:07 PM
  #63
DBH
DBH's Avatar
Originally Posted by Rich_Jenkins
So my conclusion is that all this time, at least for my CTEK model, and my car, plugging the CTEK into the cigarette lighter port was virtually pointless; or at least the car never reached the point where the CTEK could do it's job of maintaining the battery.
You should have a 12v port on the tunnel in the passenger footwell. This one remains "hot" at all times. Plug your CTEK (or whatever) in, turn it on and you're good to go.
Rich_Jenkins (04-05-2020)
Old 04-05-2020, 07:28 PM
  #64
Rich_Jenkins
Rich_Jenkins's Avatar
Yep, tried that one as well. GTG.
For a bit of fun, I put a spare 12V outlet voltmeter accessory I had lying around into the center console, to keep an eye on the voltage. Started out at 12.3V:
Within about 20 minutes, the voltage was reading 12.5V, and the CTEK had kicked over to the "full" reading. So it looks like either direct alligator clip or side port charging works, at least for my car / charger combo. Thanks for the tip.
Old 04-05-2020, 08:33 PM
  #65
achtung6
achtung6's Avatar
Originally Posted by Gary JR
I do that plus Lysol wipes.
I use disposable nitrile gloves when refueling and have done so for years. As much as I love gasoline and the joy it brings into my life, I don't feel like getting it on my hands.
Old 04-06-2020, 12:29 AM
  #66
Need4S
Need4S's Avatar
Not quite. It only remains live if you lock the car with your key fob. If you don't, its activity will eventually time out also.
Old 04-06-2020, 08:01 AM
  #67
Porsche_nuts
Porsche_nuts's Avatar
Received 1,190 Likes on 715 Posts
Talking
when you Lysol wipe with gloves on, do you have your belt and suspenders on too?
Old 04-06-2020, 08:13 AM
  #68
Gary JR
Gary JR's Avatar
Sometimes, but I'm healthy, wealthy and wise all the time, Jr.
Old 04-06-2020, 08:48 PM
  #69
DBH
DBH's Avatar
Sorry, the Battery Tender on my 2018 GTS works for weeks (2-3 months) on end with no further input from me on an UNLOCKED car.
The following 2 users liked this post by DBH:
Need4S (04-09-2020), thesaintusa (04-09-2020)
Old 04-06-2020, 09:04 PM
  #70
991.2 GTS
991.2 GTS's Avatar
Same here, except if there’s a power failure my Porsche CTEK needs to be reactivated 🙁. I’ve got a Noco Genius G3500 that I may use instead.
Old 04-08-2020, 05:10 PM
  #71
Rich_Jenkins
Well shoot now I am cursed. I have had the charger working pretty well but now it seems like it won't move off the "MODE" switch.
I unplug it all from the wall, reset everything and same issue, no worky.
Has anyone had anything similar with a CTEK Multi US 3300?
I emailed Customer Service for an RMA number and an evaluation. The manual says it has a five year warranty, so I guess I will put that to the test (bought it April last year.)
Old 04-09-2020, 12:30 AM
  #72
Need4S
Need4S's Avatar
Maybe they changed it. My car is a 2015. Anyway, glad it works for you!
Old 04-09-2020, 12:31 AM
  #73
thesaintusa
thesaintusa's Avatar
Ditto.
Old 04-09-2020, 10:31 AM
  #74
DaveGee
DaveGee's Avatar
Originally Posted by thesaintusa
Ditto.
x2
DaveGee
Old 04-09-2020, 11:45 AM
  #75
LexVan
LexVan's Avatar
Received 5,406 Likes on 2,513 Posts
Hey Rich how many megapixel is your camera? 0.1??
Quick Reply: Time to bring out the battery tender.
