Vektor Performance - Product Testers - Performance Air oil Separator for the 991.2
#62
Former Vendor
'll revise my statement above. I must have got you an another testers info mixed-up :P
#64
I have a couple on the shelf and will DM you a part number on Monday when I'm back in the office.
Something to keep in mind, the OEM hose that needs to be modified, can be put back to stock configuration by using some of the parts that come with the AOS. This makes reversing the modification a simple step.
INSTALLATION INSTRUCIONS
#66
Just installed the Vektor AOS and APR diverter valves. In a MT I can hear difference at certain shift, turbo no longer spooling in Sport plus when off throttle while shifting so diverted valves are better
mechanics said he did not see extra oil in the turbo or in tube to the intercoolers so that’s good news. 14k miles. At next oil change I will report on oil collected in the Vektor AOS
#67
What an improvement!
I was able to use the OEM nuts for the header to block interface, and all OEM hardware for the header to turbo interface save for the driver side top. I used Vektor’s included M8 hex head bolt and flanged nut in that spot.
For whatever reason, I had zero issues with the driver side turbo wastegate actuator. A light push and the header cleared it easy.
The following 3 users liked this post by Zylinderkopfdichtung:
#68
Former Vendor
Former Vendor
Closing thread.
Thank you to all the Beta testers willing to take a gamble on a new product! Beta testing is invaluable in providing a multitude of performance conditions as well as various types of feedback in regard to installation.
AOS can be found on our website, right HERE.
