Identifying PDCC
Old Oct 21, 2019 | 11:40 PM
eysa's Avatar
eysa
Default Identifying PDCC
How can I know if my car has PDCC? it doesn't specify in the build sheet(bought as cpo) so i'm assuming it doesn't but is there a way to verify without a doubt? It does have the button with the shock icon above the traction button if that means anything.
Old Oct 21, 2019 | 11:48 PM
MOWE's Avatar
MOWE
There was a thread about this months ago. OP said it had PDCC but it was not on the build sheet.
Old Oct 21, 2019 | 11:58 PM
eysa's Avatar
eysa
I searched and came up short hence the reason for this thread. I’m getting ready to order a KW HAS kit and PDCC is the only option for a different part#
Old Oct 22, 2019 | 12:12 AM
worf928's Avatar
worf928
Look at the drop links for either of your front or rear sway bars. If they look like the "top #6" you have PDCC. If they look like the "bottom #6" you don't have PDCC. These are visible from underneath or with a wheel off. The rear links might be visible with your head on the ground looking into the rear wheel well from the rear.
Old Oct 22, 2019 | 12:51 AM
_RS_'s Avatar
_RS_
Or the easy way...
You'll have PDCC along with the shock icon on that button if it has. Just the shock icon if not.
Old Oct 22, 2019 | 12:58 AM
visitador's Avatar
visitador
That is the PASM button. In later cars that button has PDCC written on it to identify if PDCC is also equipped. In earlier cars those letters were not there even if so equipped. You have to rely on the build sheet or, if serviced by a dealer, whether the PDCC reservoir was checked or changed (at six years)
[edit: see post 26, 27 https://rennlist.com/forums/991/825877-pdcc-option.html ]
Old Oct 22, 2019 | 01:03 AM
_RS_'s Avatar
_RS_
Oh.
So how old is the car, eysa?
Old Oct 22, 2019 | 01:10 AM
eysa's Avatar
eysa
My car is a 2018
Old Oct 22, 2019 | 03:36 AM
nilaz's Avatar
nilaz
Eysa you do not have PDCC. As you are considering to upgrade your suspension this proves you did the right choice.
Old Oct 22, 2019 | 03:43 PM
doctorayes's Avatar
doctorayes
That was me! I had PDCC button but not actually PDCC. I bought the car CPO and it turned out when a sport exhaust was retrofitted they put a PDCC button instead of a regular PASM. Here is the link for the thread:
https://rennlist.com/forums/991/1156...sche-pdcc.html
Old Oct 22, 2019 | 10:40 PM
CSK 911 C4S's Avatar
CSK 911 C4S
Run the VIN. See if it has the option.
Old Oct 22, 2019 | 10:48 PM
eysa's Avatar
eysa
Is that the drop links pointed by red arrow and sway bar point by the blue? If so then it doesn’t have PDCC, correct?
Old Oct 22, 2019 | 11:46 PM
arter's Avatar
arter
correct
PDCC picture
Old Oct 23, 2019 | 12:10 AM
worf928's Avatar
worf928
Yup.
Originally Posted by arter
correct
And yup.
Prima facie: no PDCC.
Old Oct 23, 2019 | 01:13 AM
Cuda911's Avatar
Cuda911
My build sheet specifically lists PDCC.
