Installed GT3RS side skirts on my GTS
Old 12-22-2021 | 10:11 AM
  #256
getPorscheSilverSpringParts's Avatar
Premium Dealer
Originally Posted by noahabel
Finally got around to installing the .2RS skirts I purchased from GetPorscheParts on Black Friday on my .1 C4S and they are AMAZEBALLS. Seriously, I didn't think something so simple could utterly transform the look of the car from almost all angles but it has. The difference from the stock skirts is night and day. I honestly thought they might be too big when I saw them on the first time but I quickly got over that. They're stunning.
Some notes on the install that may help future modders.
1. As mentioned, you have to trim back the tab that holds the slip-nut that secures the screw behind the rear wheel well liner (see post #251 above). I measured the tab on my stock skirts as 2.25" so I tried to match that (did better on the 2nd skirt). It really helps "suck in" the skirt towards the center of the car at the rear-most point. I then attached the slip-nut and punched/drilled a hole to match (3/16" worked for me).
(NOTE: The half hole you see is the original hole. You could ballpark the trim to the halfway mark of that hole.)
2, In order for the rear 2 horizontal fasteners (the large, black slotted "screws" that insert into the white "nuts" that attach to the body and come on the new skirts) to properly snap into place, you need to widen the holes on the new skirts about 1/8"-3/16". I used an emery bit on my dremel to remove some material in the direction of the outside of the skirt (away from the car). I didn't do this on the driver's side and couldn't secure the fasteners, but then did so on the passenger side and they fit correctly. I'll have to tackle the driver's side again at some point.
3. Finally, no one has mentioned this before so maybe I'm special but I released A TON of dirt, rocks and road debris from all the fastener holes and especially the rear wheel liners. I guess that was 8 years and 45k miles worth of gunk. Makes me want to take all the underbody panels off and clear it all out.
Here's the final result (I also installed the S-PASM lip spoiler, RGS grilles and black headlight washers). Love the look of my stock+ beast right now! Yes, the gap is there and it's hard not to notice when you're looking for it. I'm going to see if I can live with it and if not, I'll consider one of the solutions above.
Looks GREAT!!! Thanks for posting, and thanks again for your business!
Evan Winstead | Internet Parts Director
Shop & SAVE on Genuine OEM Porsche Parts, Accessories & Driver's Selection!
Contact Us · Shop Audi & BMW Parts too!
The following 2 users liked this post by getPorscheSilverSpringParts:
drsubie (01-04-2022), noahabel (12-22-2021)
Old 12-22-2021 | 01:42 PM
  #257
cutlass476's Avatar
cutlass476
Originally Posted by KP993
See pics below. It's about 3 to 4mm off at the rear end of the skirt. The rest is perfect fit. You can't really tell if you are couple steps away from the car.
That gap is nothing that a little judicious heat gun action (from the backside of the skirt) couldn't fix. Take them off, warm them up and then press fit them to the body's contour. You just have to be careful with the heat application. I'm betting it would work. Nonetheless, they still look great.
Old 01-03-2022 | 03:25 PM
  #258
991_T's Avatar
991_T
Originally Posted by polobai
Just realized I never updated with the pics of the less aggressive 991.1 gt3rs skirts modified to fit my 991.2 carerra t (narrowbody).
Lots of modification to the skirts to make themwork but really happy with the results
Front fitment (also added mudflaps)
Rear profile
Originally Posted by Tecni
what did you do to get them to fit? Also, con you put a link for the parts? Trying to get these for my 991.2 narrow-body
Could you explain what mods were needed to make these fit ? I just received a return message from Suncoast.com saying that these won't fit a 991.2 T.
Old 01-03-2022 | 03:46 PM
  #259
Jeahbladejeah's Avatar
Jeahbladejeah
This should be helpful: https://rennlist.com/forums/991/1181...rrow-body.html
polobai (01-03-2022)
Old 01-03-2022 | 11:55 PM
  #260
RGS's Avatar
RGS
Basic Sponsor
Looks great! subtle yet aggressive looking! Nice work!
RGS
- Radiator Grille Store
OEM Look, Economical Protection
www.radiatorgrillestore.com
Old 03-03-2023 | 10:07 AM
  #261
desmotesta's Avatar
desmotesta
Question:
Does the .2 GT3 RS Side skirt fit on .1 wide body or do I need to order the .1 GT3 RS Part?
Thank you in advance
Old 03-16-2023 | 11:15 AM
  #262
mdcm17's Avatar
mdcm17
Doing this soon. Can’t wait!
Old 03-16-2023 | 11:24 AM
  #263
Ahmad310's Avatar
Ahmad310
Are you doing the GT3 or the 4S/GTS sides?
Take lots of pics of install and let us know how the process goes... Ive been really thinking about pulling trigger on this myself.
Old 03-16-2023 | 11:31 AM
  #264
mdcm17's Avatar
mdcm17
Doing the .2 GT3RS skirts on my GTS. Will do re: pics!
Old 03-26-2023 | 10:39 PM
  #265
BlitzIS's Avatar
BlitzIS
Thinking of adding factory GTS side skirts on my C2S. Does anyone know if they will fit and if there will be any gaps like the .1 RS skirts?
Old 03-30-2023 | 12:07 PM
  #266
Ahmad310's Avatar
Ahmad310
They don't fit the narrow body 911 out of the box, it will require some trimming of the new skirts to make it work. There are several forum members who have done it all with different ways off getting it to work. Most have some minor gap in the rear. Does not seem to be very difficult to do. I just ordered the targa/gts/4s skirts and will be attempting this soon on my C2S.
Old 03-30-2023 | 02:38 PM
  #267
BlitzIS's Avatar
BlitzIS
Thank you, I currently have the .1gt3rs skirts installed on mine by modifying them. I was thinking of switching to the gts skirts and having them painted to match. Where did you purchase yours from and how much were they? Are you planning on painting them or leaving them the raw plastic color.
Old 03-30-2023 | 02:53 PM
  #268
Ahmad310's Avatar
Ahmad310
You will basically have to modify the GTS ones the same as ones you have since both GTS/GT3RS have wide bodys and the mounting points are different vs the narrow body car. I was going to order through Sun Coast but the shipping cost was like $150, so I ordered through https://www.getporschesilverspringparts.com/ they had them for slightly less and shipping was around $50.
From what I've gathered in all the post on this topic, you can get the OEM clips to work if you enlarge the holes in the side skirt, it's the rear attach points that are the tricky part to get to sit right w/o a gap. Sounds like heating them up and trying to shape them helps. I dont know when i will get to doing it on mine but I will try and take a lot of pics to document and share with people here of how my experience is going.
Old 03-31-2023 | 01:23 PM
  #269
BlitzIS's Avatar
BlitzIS
Do you have the part number for what you ordered? Just wanted to see if it’s the same one that I found. Thanks!
Old 03-31-2023 | 01:48 PM
  #270
MingusDew's Avatar
MingusDew
More info in this thread: https://rennlist.com/forums/991/1181...rrow-body.html
Quick Reply: Installed GT3RS side skirts on my GTS
