View Poll Results: What do you want to see installed first
Vektor Headers
11
32.35%
Sharkwerks Exhaust
10
29.41%
Nah! do both at the same time
13
38.24%
Voters: 34. You may not vote on this poll
Vektor Headers and Sharkwerks Install
#31
In preparation i bought a stubby 22mm and a O2 flex 22mm wrench. I cut the opening wide to slip over the harness easily.
I am thinking of removing the cats to make the install easier on the driver side.
Now only if I can get my header and exhaust so i can do this. Getting close to a month since order.
#32
Couple of shots with the endoscope - of the hard to get heat shield screw. The driver side difficult header/turbo screw is actually covered with the heat shield, will take shots of it when I am under their next. .. while waiting I got nothing else to do.Its easy to get to these with the wheel removed, I am going to use a flex attachment
#36
Just have it running on the same setup as you had the dB meter and have video going on it. Once you play with it a bit, you'll see how it works. You can change the scales in dB range (upper and lower limits) and also frequency range by using your fingers in standard screen zoom type fashion.
#39
Kelsey (12-11-2020)
#41
Side note, I've been having a little fun listeningvto music with it. You can see the bass line and vocals.
#42
Well, now I have this too.
Cargraphics Sport Cats from Germany.
Now I am debating if I should install all 3 or just 2 out of the 3.
Thinking of keeping the PSE and selling the sharkwerks, the fit and finish, ceramic coating is amazing on sharkwerks
#44
I listed mine in market place, if anyone is interested for immediate delivery.
I may comeback to it, but I am going to try the headers and cats only first.
Can't say enough good things about sharkwerks customer service and build/finish quality.
#45
I see you've already made a decision, but I would've suggested doing the exhaust and headers, in that order.
