Auto start stop
Old 11-04-2018, 01:49 AM
vodkag
vodkag's Avatar
Default Auto start stop
My auto start stop function is set to OFF as default (aka the function is disabled)
is that how it should be (default setting) or was it something that the previous owner had the dealership programmed to keep it off.
Just curious
Old 11-04-2018, 02:19 AM
arter
arter's Avatar
In Europe the default is set to on, in the US off.
Dealer could change this I believe
Old 11-04-2018, 04:23 AM
hbear
hbear's Avatar
My 991.2 defaults to the auto start/stop as enabled in normal mode......annoying but I don't drive in normal mode so not a big deal.
Old 11-04-2018, 07:48 AM
n8kruger
n8kruger's Avatar
Maybe it has Vlad's memory module?
T-design9.com
Old 11-04-2018, 10:36 AM
Porsche911GTS'16
Porsche911GTS'16's Avatar
Received 1,194 Likes on 575 Posts
In the US, the default is on. In the 991.1 generation, if you push the button to disable it, it will remain off forever if you so choose. In the 991.2, the button reverts to the factory setting - auto start/stop on - every time the car is turned off. Thus, you need to disable it every time you get in the car, if you want it off.
Old 11-04-2018, 11:16 AM
vodkag
vodkag's Avatar
ah! thanks!
Old 11-04-2018, 12:33 PM
mymac
mymac's Avatar
You could buy this " T-design Memory Module" and not have to worry. I bought 1 for my 2017 Cayenne and love it!!
Old 11-04-2018, 12:46 PM
Hurricane
Hurricane's Avatar
^ this
Old 11-05-2018, 08:19 AM
PCA1983
PCA1983's Avatar
I hate it when On. But that only happens if I forget to turn **** to Sport or Sport+ when starting.
Old 11-05-2018, 08:41 AM
PTS-BRG
PTS-BRG's Avatar
T design module is a gift from the heavens. I havent had to think about that moronic auto start stop since I installed it. Cheap, easy to install and serves its purpose..
Old 11-14-2018, 07:26 PM
Rennolazine
Rennolazine's Avatar
Do u have install instructions and how does the apple car play work with no cable? This looks awesome
Old 11-30-2018, 12:54 AM
achtung6
achtung6's Avatar
Here's a question for anyone who has the T-Design memory module. I understand the factory programming of the memory module is supposed to be A/S/S off. Should I expect the A/S/S button be illuminated when I start the engine? I just installed the module on my 2017 Carrera S and when I start the car, the button is not illuminated. All the buttons work when I press them manually: PASM, A/S/S, etc. So the A/S/S button illuminates when I press it manually just as it did before installing the module. What am I missing? I thought the module would make the A/S/S button illuminate with the remembered setting. Am I wrong in expecting this?
Old 11-30-2018, 08:27 AM
PTS-BRG
PTS-BRG's Avatar
"^^^ The buttons are supposed to be as you left them when you turned the engine off. So if the Auto Start/Stop button was illuminated when you turned the engine off, it should be illuminated when you turn it back on. If that doesn't work, take a look at the last part of the written instructions. It says to open the door, turn on the ignition and press each one of the buttons 3 times with 1-second intervals between presses. This might be an initialization process needed to enable the module."
Old 11-30-2018, 09:53 AM
achtung6
achtung6's Avatar
Thanks! I think I was expecting the A/S/S to light up from the first engine startup as the instructions that shipped with the module state that all the features are enabled from the factory. Perhaps my interpretation was wrong. I couldn't drive the car after installation so I will try it today. I'm so looking forward to having the A/S/S defeated at each startup.
Old 11-30-2018, 02:54 PM
mreloc
mreloc's Avatar
Ugh. I guess I'll have to drop two bills to buy this module- it's sorta sad that it's actually worth it to me not to have to remember to push the A/S/S button!
Quick Reply: Auto start stop
