DSC Sport V3 Control Module
First, unlike most here i actually dont think the OEM sport setting is too harsh. Could use some cleaning up in the corners and rebounding, but the last thing i want to do is make the car softer in any way (outside of maybe the comfort setting).
Currently I have Bilstein B16s, Elephant mounts, bumpsteer kit, adjustable sway bar end links and a pretty aggressive alignment.
Given the above, would DSC recommend and be able to make me a custom file to fit my needs?
PCA National Instructor
TPC Racing stats:
2023 Porsche Sprint Challenge 992 Cup Am Champion
2023 Porsche Sprint Challenge GT4 Pro-Am Team Champion
2022 Porsche Sprint Challenge 992 Cup & 991 Cup Champion
2020 IMSA GT3 Cup Challenge 2nd Championship
2018 IMSA GT3 Cup Challenge 2nd Championship
2016 IMSA GT3 Cup Challenge Champion
2013 IMSA GT3 Cup Challenge Champion
2006 Rolex-24 @ Daytona GT Champion
2004 Grand-Am SGS Class Champion
Personally I think the GT3 Tour file is the ultimate.
Just installed the DSC Sport Controller, and the buttometer says huge improvement on my 15 911.1 Turbo. Being a novice what are the differences between the factory unit and the magic box you sent me.
Huge thank you,
Graham
First, my car is a 2017 7MT 991.2 Carrera S, SPASM, PDCC, Sport Chrono, RAS with the APR K04.3 GTS turbos + APR Stage 3 tune, so according to APR's dyno charts it will put out some 554hp/556lb-ft torque in sport/sport+ mode. My accelerometer tells me I can get acceleration of around 1.02G on the street (I haven't yet been to the track - that's coming up in May).
I have seen earlier in this thread that there is another file that is a modified GT3 Touring file with, I think the lower end of the sport range has been shorted by around 10% so it will be a little bit stiffer.
Given that my car is tuned, and I very much want improvements in traction and drive for the track, should I be looking at changing parameters a little more in sport chassis mode? I'm definitely going to try the abovementioned file that stiffens up sport mode a little, but sometimes things that seem like the right thing to do (stiffening up a little) counterintuitively wind up doing the wrong thing. Are there perhaps other files that have a more track-oriented sport mode?
Next, what is the "driveline" setting - the manual has it as "track", but the actual app lists it as "driveline". I'm guessing that this is not used in the 9x1, but it's not clear to me what, if anything, it is used for.
What is 9x1 w/ LNC vs 9x1? I believe it's something to do with launch control, but I've no idea what it applies to - does it apply only to PDK cars with sport chrono (and therefore launch control), or does it apply to any car with sport chrono, or is it something else entirely?
Given that I have SPASM, sport chrono, PDCC, RAS, do I need to do the zero travel or zero ride height thing?
There's so much info on how DSC works on this forum alone that it will require a good search and read to learn about.
Here's a short version on how it works-
First, my car is a 2017 991.2 Carrera S, SPASM, PDCC, Sport Chrono, RAS with the APR K04.3 GTS turbos + APR Stage 3 tune, so according to APR's dyno charts it will put out some 554hp/556lb-ft torque in sport/sport+ mode. My accelerometer tells me I can get acceleration of around 1.02G on the street (I haven't yet been to the track - that's coming up in May).
GIven that my car is tuned, and I very much want improvements in traction and drive for the track, should I be looking at changing parameters a little more in sport chassis mode? I'm definitely going to try the abovementioned file that stiffens up sport mode a little, but sometimes things that seem like the right thing to do (stiffening up a little) counterintuitively wind up doing the wrong thing. Are there perhaps other files that have a more track-oriented sport mode?
What is the "driveline" setting - the manual has it as "track", but the actual app lists it as "driveline". I'm guessing that this is not used in the 9x1, but it's not clear to me what, if anything, it is used for.
Given that I have SPASM, sport chrono, PDCC, RAS, do I need to do the zero travel or zero ride height thing? I'm assuming not unless I go and load other files, but figured I'd ask anyway.
https://youtu.be/kAJBu8sJ2x8
All the best,
Graham
Maybe we made the mistake from the beginning of providing user's with software...LOL
1. What is the "driveline" setting - the manual has it as "track", but the actual app lists it as "driveline". I'm guessing that this is not used in the 9x1, but it's not clear to me what, if anything, it is used for. Is it for dynamic engine mounts?
2. What is 9x1 w/ LNC vs 9x1? I believe it's something to do with launch control? I saw the TPC launch control video, but in my 7MT if I have the car in gear, clutch in, and stab the accelerator pedal, I get no blinky-flashy PDCC light. Do I have to change the car selection to 9x1 w/ LNC to enable that?
3. Should I do the zero ride height procedure if I am not changing any settings and just installing the controller? Neither the manual nor the video for doing the procedure indicate *when* you should do so.
