weighed my 991.2
Old 02-17-2021, 03:57 PM
  #46
polobai
polobai's Avatar
Received 1,124 Likes on 669 Posts
Sorry forgot to add my basic spec: 991.2 carerra T, manual, 4 ways, RWS, no Sunroof, base brakes.
Old 02-17-2021, 04:39 PM
  #47
rugu6869
rugu6869's Avatar
I spent a TON of time and money lightening my E90 330. I ended up cutting 180lbs. off the car and had full interior and rear seats.
These were the significant weight savings for the car:
CF hood, roof and trunk (note: sunroof doesn't cut as much weight as you'd think - you have to install a pretty large cross bar from the factory that adds in weight. Total savings was only 15lbs.)
Wheels and tires - 8 - 9 lbs. per wheel even though I went wider
Four wheel BBK - larger calipers, but the rotors were significantly lighter when I went to two-piece rotors
Exhaust - cat back only saved 20lbs.
Front seats - Sparco road seats - while the seats themselves were lighter, you have to remember that you need mounting hardware as well. These are not light and add back in quite a bit of weight. End result I only ended up saving about 20lbs.
Light weight batter - I had a Braile battery and it worked great. Saved 28lbs over stock
For the 911, to save weight, you're going to have to get very tricky and it's going to cost quite a bit. I'm sure a CF hood/roof and light weight glass will help. I imagine this would be around 20lbs total weight savings for a car without a sunroof, but quite costly.
As you stated, the battery is a source to lighten up the car.
Litespeed racing has magnesium wheels that weigh around 17-18lbs. so you could save 7 - 9 lbs. per wheel and they cost around $8K.
A BBK or two-piece rotors will be lighter as well and save on rotational mass.
I don't know if the aftermarket suspension pieces are lighter or not. I switched to M3 suspension bits for my BMW and they were lighter than the stock units.
Going to LWB and rear seat delete will save some too. Again, the LWB cost is pretty steep.
With all of this maybe around 140lbs. weight savings. Cost would more than likely be around $40K - $60K, plus installation and painting where applicable. I had a total of $30K into my 330 when I was all done (including labor and paint).
Old 02-17-2021, 05:25 PM
  #48
polobai
polobai's Avatar
For me the only thing I can see doing is possibly swapping to really light seats (like the carbon shell seats with padding that weigh less than 10lbs (not including hardware). And doing two piece rotors when I have to replace my stock rotors. Imo as our hoods and roof are aluminum I won’t save much with carbon replacements vs the cost (the hood is reasonable but the roof panel is crazy expensive). Luckily I already have the lightweight/gorilla glass fitted on my T. If I can get to the 3153 weight with fluids then I am happy for now without spending a boatload.
F1SML8R (02-17-2021)
Old 02-17-2021, 06:30 PM
  #49
Antigravity
Premium Sponsor
Antigravity's Avatar
Received 1,007 Likes on 566 Posts
Originally Posted by I-Man
I am also hoping to get mine under 3100lbs. The Antigravity battery seems like the best bang for the buck. Which did you get? I have my eye on the 40Ah.
Hi I-Man, there are a few specialty shops carrying the automotive models but the easiest way is generally directly via our website. We'll also be having a Spring sale coming up for those that may be interested!
As always, please feel free to reach out to us directly with any questions.
Best regards,
Chad
chad@antigravitybatteries.com
Old 02-18-2021, 08:58 PM
  #50
SpiderG
SpiderG's Avatar
My Carrera T weighs in at 3186 with 1/8 tank of fuel. Options: manual, RWS, 4 ways, no sunroof, Bose, base brakes and... wait for it... rear wiper (which automatically adds the normal full weight rear glass back to the car).
polobai (02-18-2021)
Old 02-18-2021, 09:34 PM
  #51
polobai
polobai's Avatar
That also deletes the rear quarter gorilla glass as well right?
Old 02-18-2021, 10:12 PM
  #52
SpiderG
SpiderG's Avatar
That's correct. Adding either the rear-wiper or rear-defrost to a T will also automatically add standard glass all around.
Old 02-19-2021, 08:50 AM
  #53
bukit
bukit's Avatar
Originally Posted by MaynardZed
Thanks for the info. I'm going to be weighing my 991.1 GTS on my scales soon. Trying to get over 10/1 weight to power with driver for TT3 for NASA. They take the average wheel HP around top of rpm range so I think I can make it.
I used to run NASA TTA
rugu6869 (02-19-2021)
Old 02-19-2021, 09:19 PM
  #54
Valvefloat991
Valvefloat991's Avatar
When you do, weight it with a full fuel tank. These weights with various, random fuel levels are needlessly imprecise.
Old 02-20-2021, 12:34 AM
  #55
Harsany
Harsany's Avatar
Seeing the how much the 911T’s weigh is impressive
Old 02-20-2021, 11:37 AM
  #56
rugu6869
rugu6869's Avatar
Originally Posted by dsddcd
Back to life!
I finally weighed my car and it came in at 3,383#. The car does have TPC swaybars and Tractive dampers and was measured running a set GT3 wheels. I am hoping that I can pull out about 110 lb's by swapping to my Signature wheels, aftermarket exhaust, LIPO battery, rear seat removal.... but that might be pushing it.
2019 GTS, RWD, PDK, 4 Ways, RAS, Glass Roof, Full of Fuel, Bose, CL Wheels and Standard Brakes
Estimated Savings:
Exhaust - 60lb est (Headers, Muffler and Cat Delete)
Battery - 45lb est
Rear Seat - 20#
Wheels - 10#
I resurrected this thread. Just looking to see if you've done any of the weight savings mods you have listed and if you have any results.
I'm getting AP BBK more than likely today (been delayed twice already due to the weather). I'll weigh them to see the weight savings as well.
Old 02-20-2021, 12:58 PM
  #57
nilaz
nilaz's Avatar
3192 lbs.
991.2 GTS RWD PCCBs, BBS FIR, LWBs, RAS.
If I had the chance to get an Antigravity battery in Europe will be my next upgrade.
pride355 (08-15-2021)
Old 03-16-2021, 03:16 PM
  #58
rugu6869
rugu6869's Avatar
Best regards,
Chad
Any word on timing for the spring sale?
How long is the 40ma on backorder?
Bump thread too!
Old 03-16-2021, 11:01 PM
  #59
Antigravity
Premium Sponsor
Bump thread too!
40Ah models are in stock.
Sales is this weekend 19th -22nd...
15% of all Antigravity Products.
Best regards,
Chad
rugu6869 (03-17-2021)
Old 03-16-2021, 11:22 PM
  #60
stout
stout's Avatar
Received 1,309 Likes on 609 Posts
If ever you want to get a sense for just how hard Weissach worked to reduce weight in the 991 series, check the weights in this 964 C2 thread:
https://rennlist.com/forums/964-foru...4-weigh-6.html
Not a lot of great comps—with mods, a lot of 1/4 or 1/2 tank (or no gas), etc—but several suggest a stock US C2 is 3,050~, which even sounds a hair lighter than expected. Now consider all of the safety, equipment, and performance upgrades in a 991...not to mention its wheel/tire package.
Quick Reply: weighed my 991.2
