weighed my 991.2
Old Jul 23, 2018 | 01:48 PM
wareaglescott's Avatar
wareaglescott
Default weighed my 991.2
I have some corner weight scales for some other cars so figured I would weigh my C2S and see how it came from the factory. 3/4 fuel tank and about 15lbs in the frunk. No sunroof car and RAS. I weighed my '79 the other day and the '18 came in at 627 lbs heavier. (sunroof, AC, smog pump car with 39 years of grit on it)
Total weight 2018 C2S - 3325
Corner weight distribution - FL-17.7% FR - 19.1%
RL - 31.6% RR - 31.6%
Front -36.8% rear 63.2% (in comparison my '79 was 40/60)
Left total 49.3%/right 50.7%
Cross weight RL/FR - 49.3%, RR/FL 50.7%
2018 C2S - 7.91 lbs per 1 HP
1979 911 SC - 14.98 lbs per 1 HP (when it was new. haha mine has 172,000 miles and a tired motor)
For comparison my Factory Five Cobra I built - 5.16 lbs per 1 HP (and no traction control!)
And for fun
2018 GT2RS (3241 lbs) 4.63 lbs per 1 HP
As expected the 911 came nicely set upon from the factory. I don't really plan to do anything with these numbers on this car. I just figured since I have the scales anyways it wold be fun to see and make a comparison to my '79.
Anyone else weigh theirs? Would be curious how different options/models would change the weight.
Old Jul 23, 2018 | 01:55 PM
BK77's Avatar
BK77
good info, thanks for sharing!
Old Jul 23, 2018 | 02:05 PM
Rennolazine's Avatar
Rennolazine
Strong work! What other options do u have? Pdk, stereo, seats, fal, pdcc?
Nice garage too, btw!!
Old Jul 23, 2018 | 02:11 PM
LavaGTS's Avatar
LavaGTS
3400 pounds on the nose with half a tank.
RWD 991.2 GTS with:
PDK
FAL
PDCC
RAS
Sunroof
Steel Brakes
CL wheels
Alcantara delete
Bose
18 ways
wareaglescott
yes pdk, no fal, base radio, sport chrono, 14 way seats
Old Jul 23, 2018 | 02:39 PM
tango131's Avatar
tango131
Great info. The 3/4 tank of gas weighs about 80 pounds (assuming about 6.3 pounds weight per gallon according to the interwebz). So if you were running on fumes, your weight would be about 3,250 pounds (after subtracting 75 pounds of fuel). Porsche quotes the weight of a PDK S as about 3,220 pounds DIN. So pretty close to published specs.
Old Jul 23, 2018 | 02:41 PM
subshooter's Avatar
subshooter
Veteran: Navy
You can steer that Cobra with the throttle.
Old Jul 23, 2018 | 03:25 PM
Hurricane's Avatar
Hurricane
Thank you for sharing!
Old Jul 23, 2018 | 05:11 PM
wareaglescott
HA pretty much!
Old Jul 23, 2018 | 05:14 PM
MaynardZed's Avatar
MaynardZed
Thanks for the info. I'm going to be weighing my 991.1 GTS on my scales soon. Trying to get over 10/1 weight to power with driver for TT3 for NASA. They take the average wheel HP around top of rpm range so I think I can make it.
Old Jul 23, 2018 | 08:30 PM
minthral's Avatar
minthral
That's pretty good. +100 the curb weight spec.
Old Jul 24, 2018 | 12:27 AM
Cheshi143's Avatar
Cheshi143
3360 for mine, sunroof car, full tank, certified scale
Old Jul 24, 2018 | 01:36 AM
good2go's Avatar
good2go
How much does PCCB reduce the weight?
Old Jul 24, 2018 | 04:46 AM
LavaGTS's Avatar
LavaGTS
I recall 7.5 pounds per corner. Take that with a grain of salt.
Old Jul 24, 2018 | 10:41 AM
minthral's Avatar
minthral
Interesting...didn't know PCCB reduced weight. My rotors are and calipers look obviously bigger. I did a search and apparently it's about 40 lb total.
https://rennlist.com/forums/gt4/8759...th-pccb-s.html
10 lb weight reduction in rotational mass is a big huge... it's kind of like having super light wheels. In theory and tests done on the impact of wheel weight/size, it would make the car faster to accelerate and stop.
