GT2 bucket in 991.2
#91
Mine are the 991 version, and they do have the porsche crest in the headrest as well as the seat heating.
One easy way to tell which seat is which, is the base cushion on the 997 looks like it’s 2 pieces and the base cushion on the 991 looks like it’s 3 pieces (they are both just a “look” because it’s actually just one large foam cushion)
#92
Not sure I ever would have noted the difference in the seat cushions. Thanks for that!!
smceo (07-07-2022)
#93
Prepare to have mind blown (as I regularly do while working on 000-level stories): My seats have 991 numbers all over the stickers on the bottom (along with Made in Romania), have heat, and are clearly the 991 version...but have the lower cushions have 2 "panels," or just one stitched seam. The setback cushions appear to have 3 panels/2 seams.
#94
The more I study Porsche—in smaller or larger strokes—the more I realize how little I know. Part of what makes it interesting to me.
Hit a snag tonight in test fitting my driver's side bucket: Airbag light is on, and the seat heater switch lights up for maybe a second before going dark. Looks like I have some trouble-shooting ahead of me, but the first thing I noticed is that the stock US driver's side 4WSS+ seat's buckle does have wires coming out of it—which the RoW GT2 seat does not. There are also three pins and one spade missing in the RoW plug under the seat vs the US plug. Suspect 1-2 of those have to do with the seatbelt angle motor in the US seat, and maybe 1-2 of those have to do with the seatbelt wiring. Ah...this is gonna be more fun than I thought to get full functionality. Guess I will uninstall the RoW seat and order a LH buckle if the RH buckle I ordered looks good. Need to think about wiring from the new buckle to the RoW connector, and whether an additional harness is needed, and then to figure out if the reason the seat heater isn't working is because the car doesn't "see" the seat properly or something more hasslesome.
^ US driver's 4WSS+ connector
^ RoW driver's 991 folding LWBS connector
If someone sees something I don't, or am missing, I am all ears!
Also, first impressions from a quick test drive around the block:
- Seat position is fine, although I probably would like to sit 5/8- or 3/4-inch lower
- Not sure lateral support is any better than 4WSS+; wish I sunk into the seatback a bit more
- Plenty comfortable
- They look great in the car...much better to these eyes than 4WSS+
#95
What I learned last week is the driver's seat is not plug and play. It's missing the seat position sensor, so it will throw an airbag light. ...this is the last part I'm waiting on, maybe I'll get it tomorrow. I know which pins to wire it into, because I dissected part of an 18-way driver's side harness.
#96
btw, I can see the seat belt wire pins are there for your "^ RoW driver's 991 folding LWBS connector", they are the 2 on the far left of the picture above the "19". So not sure why you don't think the RoW driver's side buckle doesn't have a wire coming out of it. If it didn't have the wire, those pins wouldn't be there (check your passenger side seat. no pins.)
As for the missing pins. Pin 3 and 10 are for the seat position sensor. You'll have to add those. (I have a writeup coming soon. As soon as I confirm I've solved mine)
#97
Thanks for posting, guys. I've never seen a heated LWBS before. Interesting.
And to clarify, the seats in discussion here are the folding LWBS as were the GT2 variety supplied in the 997 / 987 gen cars, correct? Just a 991 version as offered in Europe.
#98
Yes, aka "991,981,718 Factory Option P03", "991 Folding Buckets", "991 Sport Buckets ", "GT2 Seats", "ROW 991 Buckets", and maybe more nicknames...
Zeus993 (01-05-2020)
#100
- Noticeably more rear-passenger legroom/room in general—looks like an inch or two, which is precious back there to begin with. Figured that might be the case on account of the thinner seatbacks, but didn't expect that much. For those of us with little people who ride behind SOs, this is a very nice benefit. And my SO, who is 5'6", can sit straight up in the back seat (something not possible in a 997) in a 991...with the awkward part being legroom, easing trips for three adults (and maybe even four?) across town in a pinch, as at Rennsport Reunion VI.
- US passenger seat buckle with proper stem length/angle (will report back)
- Harness for above?
- Occupancy sensor
- Driver seat position sensor
One thing I did notice yesterday was that the driver's seat is "tipped" slightly to the right. Checking a seam in the seatback of the stock 4WSS+ on the passenger side with a small level, it is...level. The same seam as well as the harness frame on the driver's side P03 folding bucket is...slightly off level—matching the visual. I'll have to see if I bolted it down "cocked," but it seemed to sit on its bosses correctly. If so, I suppose two washers on the inside bosses would be all that is needed, but I'd rather avoid using washers. What do you guys with these seats see?
"P03 Folding Bucket seats" seems like one way to nail down what these seats are, as the naming among all enthusiasts has been all over the map. I wonder if "P03" was used as the spec/option code back in the 987/997 era. Would be nice to nail down a naming convention, even an informal one among enthusiasts, as "991 bucket" seems to prompt thoughts of 918 buckets every time—especially in North America. Which is understandable.
#101
Good news, I got it solved! No airbag light on either seat, and the seat heaters work on both seats.
No, they don't. I ended up buying 1 additional 18-way wiring harness that I took apart to harvested pins/wires from. Nothing I've found that tells me what each wire does, other than tracing the wires on the harness I took apart myself.
On the main connector end (the one you took a picture of), the pins/wires are super easy to remove (which was very fortunate). However, every other connector on the harness is super difficult to remove the pins (you'd definitely need a specialized tool to make it easy).
I'm not sure why this is happening for you. But you are missing some additional pins (pins 4, 5, and 6) from the connector, which my driver seat came with. Those pins however, are going to a control box (big black box under the seat), part # 970.618.537.13. Funny part though, is I don't even know why that control box is there, or how it could be related to the seat heating, because it has 2 input connectors going in and 0 (of 1) output connectors coming out. If you're missing this, and think it's related, you can buy that part and scavenge the connectors/wires/pins from my 18-way harvesting harness if you want...
Specifically, you're missing the Red/Black-Stripe and 2 Orange wires, which are going to the control box (the 2 orange are inside the brown connector)
wongjonsilver (01-04-2023)
#102
"P03 Folding Bucket seats" seems like one way to nail down what these seats are, as the naming among all enthusiasts has been all over the map. I wonder if "P03" was used as the spec/option code back in the 987/997 era. Would be nice to nail down a naming convention, even an informal one among enthusiasts, as "991 bucket" seems to prompt thoughts of 918 buckets every time—especially in North America. Which is understandable.[/QUOTE]
From https://www.stuttcars.com/technical/...7.2-2010-2013/
jimmymoO (01-06-2020)
#103
No 970.618.537.13 boxes like yours under my folding bucket seats, and no harnesses to the main connector or to the plugs for the seat pads. Looks like I am going to need some stuff, thanks to your post, although I am not sure what to make of the box under your seat (which I may need). A bit of digging seems to suggest p/n 970.618.537.13 is a memory control box:
https://www.porschepartsnow.com/oem-...le-97061853713
https://www.partssociety.com/product...1853713-19-278
https://static.nhtsa.gov/odi/tsbs/20...81260-0699.pdf
But I cannot figure out why it would be on a bucket seat unless it also handles the seating position sensor and/or heating elements? (EDIT: No such box apparent under my stock US 4WSS+ driver's seat.) But then that prompts questions raised by your detailing of the way it is wired…
…I wonder if "P03" was used as the spec/option code back in the 987/997 era.
#104
Well, I think I found the reason the seat heat buttons light up and then go out: While my P03 folding bucket seats do have heating elements in their seat pads (the good news), those heating elements aren't plugged into anything (the bad news). That would probably explain it. I wonder if it's just a missing harness, and the regulators are mounted elsewhere, or if the regulators are attached to the bottom of the seats. Will look at my stock seats to learn more, which means I probably need to unbolt one of them again.
But I cannot figure out why it would be on a bucket seat unless it also handles the seating position sensor and/or heating elements? But then that prompts questions raised by your detailing of the way it is wired…
I just checked the UK configurator for a 991 GT3 RS, and the option on the build sheet is called "P03 Sport bucket seats"
#105
This is fantastic! My seats arrive Friday from Gert Carnewal and I came across this thread at the most opportune time. I'm anxiously looking forward to your final writeup later this week so I can get the necessary parts on order. Although we’re in the onset of winter here in the northeast, track days are only a couple months away and I can’t wait to get ‘strapped’ into a properly sorted 991.2 C4S on VIR the beginning of March.
