GT2 bucket in 991.2
Searched around but could not really find a solid answer. Does anyone know if the GT2 bucket seat (foldable one) was successfully fitted into 991.2 with the airbag adaptor? I reached out to suncoast and it looks like the 991.2 airbag adapter is not compatible with the GT2 bucket adapter. However, I've been few European Carrera T spec'ed with the GT2 bucket seat, so it seems like the solution is there.
Any insight is appreciated!
Popular Reply
!!! WARNING and Disclaimer !!!
This is not a guide, it’s just documentation of what I did, and I am NOT recommending you follow suit. Much of what is detailed below is tricking the car’s air bag system into thinking these seats are compliant. Any tampering with the car’s air bag system will put yourself and your passengers at risk. I do not take any responsibility for what you do with the information detailed in this post/thread, this information is offered for you to use or not use at your sole discretion and understanding of the serious risks involved.
When I installed these seats I quickly found out that neither seat is plug-n-play, and that I got an airbag light on my dash after installing the seats.
These are the options I had:
- Live with the airbag light always on (and potential risks associated with that).
- Have my car coded to remove/fix the airbag light. (A few places, like BGB Motorsports, have been able to do this)
- Remove parts from my original US seats and retrofit them to the Sport bucket seats. (Least expensive solution)
- Buy the necessary parts and install them on my new Sport bucket seats.
The details below show how I went about option #4 to eliminate the airbag light by "satisfying" all the car’s requirements (i.e. tricking), as well as how I retained the seat heating functionality on the Sport bucket seats.
Error Codes
These are the error codes I got when I installed the Sport bucket seats without any modifications.
Driver’s Side:
- 002804 - Seat position sensor driver 5%, open circuit
Passenger Side:
- 002B04 - Seat position sensor passenger 5%, open circuit
- 002104 - Front passenger buckle, open circuit
- 00611F - Seat occupancy detection, open circuit
Parts
Here are all the parts I bought to solve these error codes. I tried not to remove anything from my original seats (except one thing because I wasn’t sure if a new part would work without coding).
Ordered from the Dealer:
- (1) 991.622.784.01 - Passenger Seat Wiring Harness. This is the simplest harness I could find with all the connections I needed for the passenger side. It’s from a 991.2 GT3 with 4WSS+ w/ seat heating. However, I did need to modify this harness to use the correct connector for the seating heating on the sport bucket seat.
- (1) 991.803.184.07 - Passenger Seat Belt Buckle.
- (2) 9P1.980.341 - Seat position sensor. Need one for each side (driver seat and passenger seat). This actually isn’t the correct part number for a 991, because the dealer was having trouble figuring out the right part number. It’s for some other car in Porsche’s lineup (Cayenne?), but it worked well enough (even though it looks very different).
- (1) 9P1.971.391.C - Driver Seat Wiring Harness. This was a sacrificial part for me. I used it to pull some pin/wires from to make my seat position connection on the driver’s side sport bucket seat. And I used it to pull a seat heating connector off of, so I could splice it on to the passenger side harness I bought (which had the wrong type of seat heating connector).
Found on eBay:
- (1) Passenger Occupant Sensor Pad. There isn’t a good way to buy just this part from the dealer. It’s sold as a matched set with the sensor module, sensor pad, and seat cushion, which are all calibrated together (see service manual warning below). Also, this matched set is very expensive (I’ve heard something like $2500?). When searching eBay, any Porsche/Audi/VW pad ~should~ work as long as it has the right connector (typically from around 2012 to 2017 model year vehicles)
- (1) Male Seat Belt Buckle Clasp. Bought this to leave permanently installed in my new Passenger Seat Belt Buckle.
Reused from Original Passenger Seat:
- (1) 970.618.245.03 - Passenger Occupant Sensor Module. I’ve heard this part is coded to the car, and I couldn’t find one on eBay for cheap enough to test out that theory, so I just removed it from my original passenger seat (which was very easy to do).
Here's a warning from the Service Manual about replacing the Occupant Sensor.
Here's one example of an Occupant Sensor Pad that can be found on eBay. They can be found in several different shapes. This particular one from a Porsche Cayenne ended up fitting very well.
Most important thing to pay attention to when I was shopping for one of these Occupant Sensor Pads on eBay is that the black connector (pictured above) has a 3-pin layout (pictured below).
Here's a picture that shows the difference between the original 991 Seat Position Sensor, which I couldn't find the part number for, and the Seat Position Sensor I ended up purchasing for this project (which ended up working out fine).
Solving the Airbag Light on the Driver Side Sport Bucket Seat
Overview of Steps:
- Add Pins for Seat Position Sensor to the main connector of the existing bucket harness
- Connect Seat Position Sensor
This was relatively easy to un-tape. I also think I could have removed the Seat Position Sensor Connector and pins from my original driver's seat harness (if I didn't want to buy this extra harness), without being destructive to the harness.
Here's what the Seat Position Sensor Connector and pins looks like once removed from the main harness connector.
Then I simply wired that connector I just removed to the Driver's Seat Harness that comes with the Bucket Seat. Here's the pin layout:
Here's what the main harness connector will looked like once I was done. Also note that each of those pin blocks within the yellow connector (the grey, grey, and black pin blocks) easily slide out; the yellow plastic is just a shell holding all those blocks together.
Here's the completed underside of the Driver's Side Bucket
Solving the Airbag Light on the Passenger Side Sport Bucket Seat
Overview of Steps:
- Install new Passenger Seat Wiring Harness
- Reuse Thorax connector from existing bucket harness
- Install and Connect the new Seat Belt Buckle
- Connect Passenger Occupant Sensor Module
- Connect Passenger Occupant Sensor Mat
Fixing the Seat Heating on the Passenger Side Sport Bucket Seat
Overview of Steps:
- Splice the seat heating connector from new Passenger Seat Wiring Harness to correct seat heating connector needed by existing bucket harness
The new Passenger Seat Wiring Harness that I bought doesn't have the right 4-pin Seat Heating Connector needed by the Passenger Side Bucket Seat. It does have all the seat heating pins and wires, but they are just going to the wrong type of connector. So I spliced those wires onto a connector that I harvested from the Drivers Seat Wiring Harness. I created a custom Molex connector to join the two halves.
The Passenger Seat Wiring Harness that I bought has this connector:
But I need a connector that looks like this, so I clipped this connector from the Drivers Seat Harness that I bought.
Then I followed this pin layout from the original Passenger Side Bucket's harness seat heating connector:
And created this custom seat heating adapter/connector:
Result
The seats look great, and no airbag light!
Bonus Parts
Plastic Trim Pieces. These go on the front of the slide rails. If I already had manual fore/aft adjusting seats, then I could have just reused all my existing trim. But with the fully electric seats, I could only reuse 2 of 4 of these trim pieces (plus I broke 2 of them, so I just bought a whole new set).
- 991-521-361-00 L
- 991-521-362-00 R
- 991-521-360-00 R
- 991-521-359-00 L
- Cantrell: https://cantrellmotorsport.com/produ...side-mounts-2/
- Tarett: https://www.tarett.com/items/986-987...slb-detail.htm
- BBi (does it fit this seat?): https://www.bbiautosport.com/product...and-slider-kit
I repeat, this is not a guide, it’s just documentation of what I did, and I am NOT recommending you follow suit. Much of what is detailed above is tricking the car’s air bag system into thinking these seats are compliant. Any tampering with the car’s air bag system will put yourself and your passengers at risk. I do not take any responsibility for what you do with the information detailed in this post/thread, this information is offered for you to use or not use at your sole discretion and understanding of the serious risks involved.
http://carnewal.com/products/991/p91...-:-991-version
I don't believe Porsche supports these seats in the U.S., likely as a result of having to certify yet another seat for the U.S. market and a decision that most customers would prefer the new 918-style bucket, and their absence from Suncoast and other usual vendors who sell desirable RoW parts is interesting.
For all that, they certainly are appealing. I saw a set of them in a 991.2 Carrera GTS while in the UK last week and was reminded how well they fit my form and how their ultra-thin backrest might even add a bit of leg/knee room for rear-seat passengers.
If that is the case, anyone can confirm the 991 version GT2 bucket seat is plug and play in the 991.2?
I would totally opt for getting 918 LWB but except they're nearly impossible to get them here in the US after configuring the car. And folks are selling them at the cost of a kidney. I wish Porsche would allow folks to order them after delivery as long as the car was qualified to order from the beginning. 1 per customer attached to the VIN or some type of rule.
The new 991.2 GT3 seats are fixed and I think are quite difficult to access the back area.
I put mine in from my last car and they work.
I had them in my last 997.2 and they were successfully installed in the 991.2. I think they took apart the electronics from the original 991.2 seats and reinstalled them in the GT2 Carbon buckets. I wanted this to use a HANS device with a proper track set up.
It can be done with a good Porsche Mechanic who is willing to be a little creative.
Good Luck
SuncoastParts.com
Your #1 Source for Genuine Porsche Parts and Accessories on the Web!
Visit us at http://www.SuncoastParts.com
Call us at: 877-923-1700
Email us at: Parts@SuncoastParts.com
Follow our Project 718 Build Thread!
Stay connected:
Join Our Newsletter
I will say the 997 GT2 seats looked great in the 991.2 GTS that I saw in England, maybe better in a 991 than in a 997—which I would not have predicted.
I wonder if anyone in the Bay Area has them in 997 I could sit in.. and wonder how they are in height.
Height is the one bummer with these, as they sat me up a bit higher in 987s or 997s that I like. It wasn't bad, and I figured that I might have a shop modify the stock brackets or make me new brackets if I owned a car with them. They looked like they sat lower in the 991 I saw with them, and I now wish I had asked to sit in the car.
I’ll reach out to Mooty to see if there’s anyone I could meet to sit in the car. Thanks!
Need to find out if it works first!
