View Poll Results: I want a big red brake kit for my Carrera T!?!
Hell yeah, with a nice group discount.
55
74.32%
Nah, the stock brakes are good enough for me.
19
25.68%
Voters: 74. You may not vote on this poll
Hey Suncoast, how about a Carrera T big brake package deal?
#61
Sorry to join in but was enjoying the read. I just cooked my brake fluid in my 991.2 GTS. I have the 6 Pots up front and 4 pots in the rear. Its not enough. As no one has mentioned how to get some nice improvements I will here.
1. Get Braided/Steel lines
2. Up grade your brake fluid to at least a 600, or if heavy track use Castrol SRF. (Its expensive per litre, but you don't need much.)
3. Next is a pad up grade
4. Then a rotor upgrade
5. If you are still not happy with any of those, you will need a full BBK.
I am wondering if I can use 380 GT3 rotors and pads with my GTS 6 pots?
#62
Tell that to the guy in the AMG GTS in front of me LOL. I can't run up the back of him, so I have to brake harder. LOL
#63
Sounds like your problem is cooling and I suggest you research what cooling duct is best for the GTS. The GT3 comes with them but GTS does not.
Bigger rotors won’t fix your overheating issue without proper cooling.
#64
Upgrade Front Brake Line Steel Braided with red coating
Upgrade Rear Brake Line - Steel Braided with Red Coating
#65
Nice, cooling ducts. Did you install them?
If yes, what are the part numbers?
#67
In the PET system the items are called “Spoilers.” Here are the part numbers. There are two numbers for L & R. You just have to choose the right part for your vehicle. Some are for Boxers and others for the AWD, S and GTS, etc.
Rear Suspenion Part List
Rear “Spoiler” or Brake Air Duct.
Front “Spoiler” or Brake Air Duct.
Front Suspension Part List
#68
Great, thank you. Amazing price too.
#70
Thanks, Pete.
All makes sense, and has me thinking that keeping the calipers and pads while increasing the front and rear rotor size (in such a way to preserve the balance) would be preferable for the 991.2 Carrera. May be easier said than done. Fwiw, a recent run on the loop with a T on the standard brakes surprised me: They were up to the task. I suspect the Tenerife car had pads that weren't bedded in...kinda like a 718 GTS here in CA two weeks ago. Maybe the margin for bedded//not bedded is thinner with the turbo engines. Still looking into it.
#71
Nah, but that's usually a function of tire grip. Though I didn't encounter smell in northern California like I did in Tenerife, or a longer-ish pedal like I did in France, I still wouldn't mind more cooling and/or bigger rotors. Or, if the right rotors exist, a rotor/pad change to CCB rotors. If I am dreaming, they'd be GM parts, because the prices sure are right.
#72
Thanks! Maybe just ducts/pads/fluid/lines is the way to go for a low budget solution.
