View Poll Results: I want a big red brake kit for my Carrera T!?!
Hell yeah, with a nice group discount.
55
74.32%
Nah, the stock brakes are good enough for me.
19
25.68%
Voters: 74. You may not vote on this poll
Hey Suncoast, how about a Carrera T big brake package deal?
Old 06-03-2018, 01:07 AM
  #46
Valvefloat991
Valvefloat991's Avatar
Originally Posted by Pointbye
Better yet, please explain to us how a 3 piston brake caliper works.
Believe it or not, Jaguar used three-piston brake calipers in the Sixties. I think the peculiar design was motivated by packaging constraints.
Old 06-03-2018, 01:26 AM
  #47
Sidvicious7
Sidvicious7's Avatar
Front outside
Front garage
Canyon run
Originally Posted by .moo.
Any pic with the wheel on after the upgrade? This looks good!
sure...thx
Old 06-03-2018, 03:30 AM
  #48
Wing Commander
Wing Commander's Avatar
Received 1,307 Likes on 480 Posts
Beautiful 991. 50th Anniversary model?
Old 06-03-2018, 03:45 AM
  #49
Churchill
Churchill's Avatar
Wouldn't it be a lot cheaper to simply buy an S and have a tuner flash a chip with 60 less horsepower? I'm not trolling here. You'd end up with the exact same car.
Old 06-03-2018, 07:15 AM
  #50
Rennolazine
Rennolazine's Avatar
For the price of an otherwise identically spec'ed S you can buy a T plus add carbon ceramics and ecu flash...
Old 06-03-2018, 07:47 AM
  #51
Jordan Pryce
Jordan Pryce's Avatar
Let’s keep to the topic please.
Old 06-03-2018, 11:20 AM
  #52
Sidvicious7
Smile
Yes......
Old 06-03-2018, 01:20 PM
  #53
Valvefloat991
On the 991.1, the stock rotor sizes were:330 x 28330 x 28340 x 34330 x 28
On the 991.2, they are:330 x 34330 x 28350 x 34330 x 28So, the while the rear brakes are identical on all of the cars, the fronts are thicker on the base 991.2 and 10mm larger in diameter on the 991.2 S. Going to the Girodisc rotors on the base car will get you to the S rotor size with the 4-piston calipers. This should provide a small increase in front brake fade resistance, where it is likely needed.
Even with no track aspirations, I plan to make this change, when my 991.2 C2 needs front brake rotors.
Old 06-03-2018, 01:23 PM
  #54
Valvefloat991
330 x 28 330 x 28
340 x 34 330 x 28
330 x 34 330 x 28
350 x 34 330 x 28
See above, the Rennlist system takes out extra spaces and renders charts senseless.
Old 06-03-2018, 02:51 PM
  #55
Petevb
Petevb's Avatar
Originally Posted by stout
With same calipers on larger rotors, one supposes that the leverage of those pads might go up—but their work, too...without them getting "stronger." Then again, new front calipers with piston sizing that is a compromise might be a bigger problem. Would be curious to hear PeteVB weigh in on this. But I will say: The Baer brake upgrade I did on my XR4Ti years ago was front only and transformed the car's braking performance.
Brake math is generally pretty straightforward. Moving the caliper out by using it on a larger rotor increases its mechanical advantage and increases front brake toque proportionally. Measure from the centerline of the caliper pistons to calculate the change. To bring the brakes back into balance you can (in order of preference) use a caliper with less total piston area, change the brake bias valve (or master cylinder) or use a brake pad with a lower coefficient of friction. I’ve done each of these on different cars with decent results.
Older cars often do well with more front brake bias if you’re mounting modern sticky tires on them. The stickier the tire the more weight transfers forwards, so they’ll often do well with a front only upgrade. Modern cars are pretty well dialed I from the factory and use a more sophisticated pressure balancing system, so my strong preference is to keep the brake torque and pressure near stock. Once you start changing pad friction you can get unintended consequences (strange behavior when cold, etc).
Old 06-04-2018, 04:32 PM
  #56
uhn2000
uhn2000's Avatar
Yeah but you don't get the cool T stuff, interior (that I love), the door handles - fun, and apparently less sound deadening. BTW I specc'd an S the exact same way as the T and it was only $10k more but it didn't have the interior differentiation. I don't speed or try to even go fast so the base car, I hope, will fun as ever!
But on to the brakes, I am open to it but honestly I want to see how the base ones feel first. I don't care about looks so much on a GR car.
Old 06-04-2018, 05:48 PM
  #57
stout
stout's Avatar
Received 1,319 Likes on 613 Posts
Thanks, Pete.
All makes sense, and has me thinking that keeping the calipers and pads while increasing the front and rear rotor size (in such a way to preserve the balance) would be preferable for the 991.2 Carrera. May be easier said than done. Fwiw, a recent run on the loop with a T on the standard brakes surprised me: They were up to the task. I suspect the Tenerife car had pads that weren't bedded in...kinda like a 718 GTS here in CA two weeks ago. Maybe the margin for bedded//not bedded is thinner with the turbo engines. Still looking into it.
Old 06-04-2018, 06:47 PM
  #58
Jordan Pryce
Thanks, Pete.
That's exactly what girodisc is doing, increasing both front and rear rotor sizes and keeping the proportioning the same. That's why I like this idea so much!
Old 06-04-2018, 06:55 PM
  #59
Valvefloat991
Your analysis is spot on, but the question is whether it would make a great deal of difference. Even on the rear-heavy 911, the front brakes do the majority of the work when you are driving very quickly, so they are likely to fade first and thus benefit more form the larger rotors, in both leverage and heat dissipation.
I haven't examined the brake pads in a 991.2, but I would guess that they are about 2 inches wide. If so, with the 330mm rotor on the base Carrera/Carrera T, that would suggest a working radius of about140mm, or 5.5 inches. Going up to a 350mm rotor with the calipers spaced outward by 10mm would increase that radius to about 150mm or 5.9 inches. That's about a 7 percent increase, which doesn't strike me as too much.
Moreover, these cars have ABS, so any small disturbance to the brake balance would still not lead to any undesirable front or rear lockup.
Old 06-04-2018, 10:17 PM
  #60
4 Point 0
4 Point 0's Avatar
Received 1,278 Likes on 676 Posts
Sorry to join in but was enjoying the read. I just cooked my brake fluid in my 991.2 GTS. I have the 6 Pots up front and 4 pots in the rear. Its not enough. As no one has mentioned how to get some nice improvements I will here.
1. Get Braided/Steel lines
2. Up grade your brake fluid to at least a 600, or if heavy track use Castrol SRF. (Its expensive per litre, but you don't need much.)
3. Next is a pad up grade
4. Then a rotor upgrade
5. If you are still not happy with any of those, you will need a full BBK.
I am wondering if I can use 380 GT3 rotors and pads with my GTS 6 pots?
Quick Reply: Hey Suncoast, how about a Carrera T big brake package deal?
